Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prerequisite-only guide for detaching the display assembly from the iPhone 8 Plus.
Выберете то, что вам нужно
Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
One 1.0 mm screw
One 1.2 mm screw
Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
6 участников успешно повторили данное руководство.
