Введение
Learn how to replace your iPhone 8 Plus screen. This part comes with the front facing camera, earpiece speaker, and EMI shield already installed, making for an easier repair. If your screen did not come with those things pre-installed, follow this guide instead.
All you need to do is remove the old screen and transfer the home button to the new screen, in order for Touch ID to function.
Note: If your iPhone’s auto brightness feature does not work properly after your screen repair, make sure your iPhone is updated to iOS 12. True Tone functionality is disabled after a screen replacement, even when using an original Apple screen.
Выберете то, что вам нужно
Видео обзор
Power off your iPhone before beginning disassembly.
Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Инструмент, используемый на этом этапе:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
6/14/23 I did this repair but used a heat gun on low for 60 seconds. This allowed me to open the case as the instructions say, but in the end the Home button failed. I probably over heated it. I used this "go around" for a virtual Home button. I don't care about touch ID:
Apply a suction cup to the lower half of the front panel, just above the home button.
Using just the single suction cup that is included in the battery replacement kit probably wouldn’t open the device. An iOpener and an iSlack should be the recommended method. However, you can get it open with just the single suction cup and iOpener, but does take a lot of time.
Get an iOpener and iSlack with the battery replacement kit.
I used a flat x-acto (#18) blade knife tool to gently pry back the screen enough to allow me to insert the pick near the bottom corner. I then worked the pick under the screen as mentioned in steps 5 & 6 below then. This worked really well for me.
I used the suction cup without heating the phone - the adhesive came away quite easily without applying any heat. Maybe due to age of phone (nearly 4 years old). Worth trying.
My screen was very shattered, and was quite hard to get suction, as my tape was very low quality. However, after pulling it up a little bit, I was able to insert a regular razor blade into the very small gap and used that as a lever.
Oh my goodness! Don't do that again. You can definitely damage something in the phone if you use a sharp metal razor blade..
cytur -
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick or other thin pry tool a few millimeters into the gap.
After multiple tries and using a very hot iOpener, it will not open.
In sheer frustration, I pulled out my trusty pocket knife and managed to lift the bottom of the screen slightly, but in the process, cracked the glass from the bottom to the home button. The case is open now.
Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
Stop near the top left corner of the display.
Do not go over the top otherwise you can crack the screen. Sadly happened to me :(
The instruction should be:
“Stop near BUT BEFORE REACHING the top left corner of the display”
Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
I had really good luck using a hairdryer on some of the more stubborn portions of adhesive.
Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
Be very careful at this step. The glass at the top will break very easy when the display is lifted too much.
Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Das “links” ist auf dem Foto rechts.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
Two 1.3 mm screws
One 1.4 mm screw
One 2.7 mm screw
The Phillips screwdriver bit is the PH000. The measurement refers to the screw length.
Use the point of a spudger to pry the battery connector up from its socket on the logic board.
Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
When I reassembled the iPhone 8 Plus, I had to plug it into a Lightning cable to wake it up (just pushing power button wasn’t sufficient).
Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
I got hold of a iPhone 8 Plus with cracked screen that I am planning to fix.
Here is my problem:
When I tried to take out the screen from my phone, (step 15-18) I was curious about the new screen, so I tried to connect it. It was completely dead! Then I tried the old cracked one, and suddenly that was dead to! This is a phone that some fool has been inside earlier and changed battery, but I suspect he has done some more really stupid things. The Taptic Engine is living its own life and vibrating every time I slightly touch the home button. (I have a new Taptic Engine) The phone is also full of dust and small particles that does not belong there. One tri-point Y000 screw (step 18) is even missing! Now the biggest problem is that both screens are black! I know the phone is on, because I hear voice command speak when I turn on the power. The screen worked before I tried to change it? And one last thing: My new LCD screen came with new flex cables. Is it possible to switch over, so I can use the old ones?
Hi,
Is your problem solved?
Be careful of damaging MOSFETs by the LH side of the large lower display cable. After replacing the battery and turning the device on, the phone showed low charge and didn't have a charging symbol even after plugging into multiple cables and chargers. Turns out I had damaged the logic board attempting to disconnect the connector.
Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
I used the other end of the spudger on this connector and it seemed to work a little better for me. I came in from underneath the top-right edge instead of the bottom right.
Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
One 1.0 mm screw
One 1.2 mm screw
una vite da 1mm e due viti da 1.2 mm???
Ciao Matteo! Grazie per l’osservazione. Ho appena modificato il testo :) La traduzione è aperta a tutti. Hai quindi la possibilità di fare le tue suggestione direttamente nel testo e sei il benvenuto se vuoi usare di questa possibilità nel futuro. Grazie ancora per la vigilanza! Saluti, Claire
The tool kit does include a 1.0 or1.2mm screwdriver! How am I supposed to remove those screws?
Bought the screwdriver that supposedly fits these screws and it still doesn’t work.
My bracket looks different. Can’t get these screws out.
kit came with wrong bit. i received 2x P02 (penta tips) and no tri point y000.
Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
Remove the display assembly.
Should there be a step somewhere in here to point out when to remove the blue plastic from the new iFixit screen?
Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
One 1.2 mm screw
Three 1.3 mm screws
The 1.2mm screw on the home button stripped for me. I ended up bending the bracket on each side in order to remove the home button. I then bent it back as best I could during reassembly and screwing it down.
Pry under the left edge of the home button cable connector to disconnect it from its socket.
I accidentally severed the cable, now my sensor is disabled. So far this was the most delicate cable I encountered because it was so small.
Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
This did not work for me…. ended up breaking the connector from the home button. Most likely messed up the customer’s iPhone… the adhesive would not pry up with just pick… does iFixit offer a home button replacement?
did not work for me either, also ended up breaking the connector, just use the tweezer to separate it. do not use opening pick!!!!! it’s too thick for it!!
Isopropanol and heat will loosen the adhesive and its possible to gently remove with plastic pick, metal tweezers risk damaging the Home button cable and disabling the Touch facility.
Pretty easy to follow instructions if you have patience and careful hands. If you have clumsy hands you will not succeed in fixing any small electronics. There are some small things you should use to help you succeed at fixing small electronics, like some scotch tape or other clear tape to hold some of the cables in place while you work on small electronics items, also a small heavy bottle or object to propped the iPhones cases against to hold them from falling over so that your hands can be free to perform your tasks. Great job you are doing iFixit personel and I am with you all the way with fighting for our rights to fix our electronics equipment.
Isopropanol in conjunction with the heat really did the trick here. Heat up first, then use plenty of the alcohol to pry it up carefully using the pick.
Heat dryer on high worked for me.
I heated the tip of a thin knife with a hot air gun and slide it under the flexible cable. When I hit resistance I reheated the knife. Keeping it parallel to the board while doing this. After 4 heatings the knife moved the rest of the way and the cable lifted easily off of the iPhone back. This method left enough glue on the cable that it restuck fine when moved to the new iPhone.
Apple loves to make this the most difficult thing. I've been successful many times, and not so on other repairs. I just finished a repair and everything was in tact, but sadly it didn't work. Took a part and put back. So I turned on the assistive touch home button. They will be getting a new phone soon, so not a big issue except Pride.
Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
311 участников успешно повторили данное руководство.
36 Комментариев
Very useful information…
Has anyone found out any info about replacing the Apple iPhone 8 Front glass. Last I checked Apple had made it that if you install a non OEM screen and updates their phone, it will brick there phone. I have not been fixing any iPhone 8’s or iPhone x’s due to this. I So if someone knows if this has been resolved or if this still holds true can you please let me know. Also, Fixing back glass. From what I have seen they use some crazy glue. Does anyone have any methods on a easy way to replace back glass on the iPhone 8’s ? do you still basically have to gut the phone ? what kind of glue is used to glue it back on? Any help with these issues would greatly be appreciated I have been repairing phones for over 8 years + and turning away customers because apple is so dumb with these things upsets me greatly. I loved repairing iPhone up until this point. Help please.
Replacing the screen will not Brick the iPhone, although the 8/8Plus & iPhone X all have an issue with the Ambient Sensor when a new screen is fitted. Although a way around this is to use a EEPROM device to copy the firmware from the original screen. It is also rumored that Apple are fixing the Ambient Sensor issue in iOS 12.
Donald -
Why don't you just throw an oem replica decal over the back glass and call it good. Any more time spent on something that is designed to break & devalue your device into a state beyond reasonable repair efforts, to inevitably promote purchase of a newer model, should be treated with scorn and covered with cheap adhesive decals from China.
Anyone know if the ambient sensor is fixed?
Hi. My iphone 8 plus screen is broken. I purchased it from USA, I’m in Turkey, Istanbul right know. When I took it to the apple store over there, they told me I need a code to replace the screen, and every country has different code. In order for me to replace the screen, I need that code.
Would some one please tell me what to do. I really appreciate it.
Thanks.
I replaced the screen on an iPhone 8 Plus. When I transfer the home button it does not work in the new screen, but still works in the old, cracked screen. Thoughts?
I’m having same issue and tried numerous aftermarket screens, I had a spare 8Plus here ready to repair (lcd damaged but working) tried it on that separate screen and Touch was fine again so the issue has to be aftermarket screens I’m guessing it’s the quality of the lcd is the issue as all original screens have proven fine but 3 aftermarket screens later and no joy so worth paying a little more for oem quality. The8plus is the only model so far Iv had this issue with as prior models are simple, but so many advertised as “original” it’s hard to pin point decent supplier
I successfully substituted the screen with ifixit kit. However, force touch does not work and the luminosity is way less than the original
Did the replacement yesterday on my own with the iFixit kit and the parts supplied. It was really easy and great that it came with the adhesive and all the parts integrated in the replacement screen. The only downside is that the TrueTone isn’t working anymore nut I knew this before buying the kit.
It took me about 2 hours to complete.
I forgot to disconnect the battery connector now my iphone 8 won’t boot up any idea how to fix this ?
My home button is not recognized with the new screen fitted, so I’m left with putting the broken screen back in and a smaller bank balance :-(
Front camera removal is not even mentioned. That seems like a rather large omission on this replacement. Wonder how many people followed this document to the letter only to find out that the front camera is still on the old screen.
Hi Danny,
Thanks for the note! As stated in the introduction, this guide is written for the replacement part we sell, which comes with the front facing camera, earpiece speaker, and EMI shield already installed. I will amend the instructions to point to a front facing camera guide.
After I completed the repair on my iPhone 8 Plus, there’s some time of back lighting/impact point on the bottom right of screen. Anyone else’s repair have this issue??
thank you Jeff and the ifixit folks… great attention to detail. worked out very nicely in practice
Hi i fixed using this guide, i got to say it is incomplete. You need to remove the metal frame from the original screen as well and also the top of the original screen the camera module and speaker module. And the reminder and the removal of power cable need to be extra careful in choosing the right cable to unplug. I unplug the wrong one and it caused my touch ID not to work. Take note on this pointer.
Hi! This guide is written for our iPhone 8 complete screen, which has the metal frame and camera/speaker module pre-installed. We also have a guide for the bare LCD/digitizer part, which requires transferring the frame and front assembly.
Hello, I replaced the display of my 8 plus using the instructions and your replacement display. Now the phone discharges very quickly and gets warm ?! If only I had kept my broken display. What can i do?
I replaced the front screen on my iPhone 8 Plus with an iFixit kit and when I turn the phone on you can feel the phone vibrating when you click the home button but the screen is black and won’t come on…. any thoughts? I took it back apart 3 times disconnecting and reconnecting the connectors and it never would come on…. I need HELP!!!
Hi Payton,
I would check if the screen backlight was blown out. This commonly happens when you disconnect the screen without disconnecting the battery first. To check, “turn on” the phone as you have been. Shine a bright light directly at the screen, and see if the LCD shows anything. If it does, the LCD is working, but the backlight circuitry is broken.
I have this same issue
i tried the bright light idea, but cannot see anything
This is the second ifixit screen replaced on my iPhone 8 Plus. Unfortunately, this second repair kit was a much lower quality that the first one, which was only one year prior. The screen is much lower quality with really poor contrast. It works, but it makes it look like a cheap knockoff phone now. Also, two bits in the included tool kit were too large to use! They are marked the same size as my previous kit, but they are definitely larger and will not fit into the tri-lobe or philips head screws. I ended up using the bits in my previous tool kit. Overall the quality of the components has definitely gone down hill, which is hugely disappointing.
Hi Mark,
I’m really sorry to hear about your experience with the screen kit. Thanks for bringing this up—we take pride in the quality of our tools and components and seek to rectify any issues that show up. If our customer service team has not reached out, please contact us here.
Performed successful replacement of an iphone 8 plus screen. The blue triangular plastic opening pick was useless for opening the case, even after using a heat gun to soften the adhesive. A razor blade was necessary to separate the screen from the body, then the picks could be used. All other aspects of the repair guide were excellent.
Brilliant instruction. I found the screen replacement really easy to follow. Thanks!
Bought this part fitted it all working fine put a screen protector on, thought all was sorted and noticed it had a horrible screen/lightbleed issues on the right side! So So annoyed with this..
No country code needed, Thats pure BS. I replaced mine… iPhone 8Plus in 25 minutes. The phone has no coded parts except the finger print sensor. If you remove the touch id button according to these instructions you’ll have no problem with this. BTW I have done dozens of screen replacements using parts from iFixit and have NEVER had a problem. If you’re careful and make sure you have the correct model numbers for your phone you’ll get parts that work perfectly. Also big thumbs up on the guide. Excellent instructions. But somebody should write up the part about installing the glue. That’s a tricky bugger. Always remember to leave the fine assembly plastic covers in place on the glue until your ready to assemble. Keeps the glue from sticking to your cables during the final re-assembly phases. The covers are split so they wont be difficult to remove once done.
Hi. Followed the instructions. Now when we switch on we get the apple symbol for a few seconds. Then it goes off and repeats. Any suggestions please? Thanks
I bought a cheap, cheap, cheap replacement screen from somewhere else, and didn’t realize that i also had to switch over my earpiece, sensor, backplate, etc. it was a big surprise but with the help of the other tutorials on this site I was able to complete it! the screen quality is a lot lower than expected, a tad fuzzier, but you i got what i paid for. great info!!
I replaced a broken screen on my daughters iPhone 8 plus and now it will turn on but it only displays a apple logo screen on and off. Please tell me it can be fixed
I am hoping to find a fix also. I came here based off of 6 plus issues that came up when I searched. But if not the screws being placed in the correct spots then it could be a few things if it’s like the 6 at all...? My niece allowed her friends to rip hers apart now I’m left with the pieces of not knowing how it came apart or names of anything bc I’ve never messed with a replacement before. Although the home button and camera we’re supposed to be the only parts switched over I’m still in a boggle. I hope someone decides to answer! A few people with the 6 said they left it plugged in over night flashing and it worked. Thinkn about tryn but I’m afraid not knowing if the screws are properly placed first! Good Luck
Hi, my iphone 8 plus was run over and both the front and back were obviously heavily damaged. I read that if the back is damaged, you would need to replace the whole chassis and place all of the internal components into the new one. Do you sell the whole chassis? I see the front screen but not the rear.
what do I do about super stripped screws?
Ean Palacios - Ответить
I’m sorry, your comment slipped past my radar earlier. For future fixers that might see this and ask the same question, you can check out our stripped screw guide for some detailed advice.
Adam O'Camb -
Do you need a toolkit like the essential toolkit
Adam Palmer - Ответить
Hi Adam. Having a tool kit with all of the listed parts above is best. The screw heads are very small and each set of screws needs a very specific type of driver to remove them without stripping any of them.
Kyle Luksa -
