Введение
Use this guide to replace a broken front panel earpiece speaker in your iPhone SE.
This earpiece speaker is compatible with the iPhone 5s speaker.
Выберете то, что вам нужно
Power off your iPhone before beginning disassembly.
Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and for the bottom of the screen to open.
Skip the next three steps.
If you don't have an iSclack, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the screen.
Open the phone just enough to reveal the metal bracket covering the home button cable.
Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
Use the tip of a spudger to push the bracket free and remove it with tweezers.
Use the tip of a spudger to pry the home button cable connector up out of its socket.
Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
Remove the following screws securing the front panel assembly cable bracket to the logic board:
One 1.7 mm Phillips #000 screw
One 1.2 mm Phillips #000 screw
One 1.3 mm Phillips #000 screw
One more 1.7 mm Phillips #000 screw
Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
Remove the two screws securing the upper component bracket:
4.0 mm Phillips #000
2.3 mm Phillips #000
Gently dislodge the clip, near the bottom left corner of the earpiece speaker bracket, outwards from its recess on the front panel assembly.
With a set of tweezers, shift the bracket to the left to unclip it.
Place the earpiece speaker bracket over the speaker so that it fits snugly in its housing.
Slide the left hook of the bracket into the notch above the top left corner of the front facing camera.
Rotate the bracket so it lays flat on the rear case, aligning the two screw holes. Press the bracket into place, ensuring the hook on the right side of the metal bracket latches onto the display.
24 участников успешно повторили данное руководство.
3 Комментариев
So I’ve replaced my screen in my SE once after buying it second hand, and would like to start flipping phones; that part doesn’t really matter.
In step 17, the right hand side for the viewer is sticking up a bit higher than the left hand side. My phone hasn’t been dropped since I replaced the screen, but there is a massive crack where the earpiece speaker is, going the entire way across. I reckon I’ve put in the earpiece speaker correctly, but the bit in step 17 is nearly the same in my phone; sticking up a little bit.
Could it be that I over-tightened the screws? Did I not place the earpiece speaker in correctly? I’ve checked locations of the screws and nothing is wrong with those, and it looks straight-up fine.
I know this is more of something to put on a normal post or question, but I put it here to reference step 17. I need help on this before I replace the screen again. (Using legitimate apple screen, just refurb glass)
can i get a confirmation that this part is compatible with the 2020 SE?
This part is not compatible with the new SE. You would need the iphone 8/SE part.
