  1. Этот шаг не переведен. Помогите перевести
    Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • If the screws are stripped or damaged, replace the screws.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. Этот шаг не переведен. Помогите перевести
    Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. Этот шаг не переведен. Помогите перевести
    The next two steps demonstrate the iSclack, a handy tool that we recommend for anyone doing frequent repairs. If you aren't using the iSclack, skip down two steps for an alternate method. If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone X.
    • The next two steps demonstrate the iSclack, a handy tool that we recommend for anyone doing frequent repairs. If you aren't using the iSclack, skip down two steps for an alternate method.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone X.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Press both suction cups firmly into place.
    • If your display or back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cups to adhere. The iSclack also includes two pieces of tape for this purpose.
  4. Этот шаг не переведен. Помогите перевести
    Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone. Don't try to completely separate the screen; a small opening along the bottom edge is all you need. Insert an opening pick into the gap.
    • Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone.
    • Don't try to completely separate the screen; a small opening along the bottom edge is all you need.
    • Insert an opening pick into the gap.
    • Skip the next two steps.
  5. Этот шаг не переведен. Помогите перевести
    If using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass. If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • If using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. Этот шаг не переведен. Помогите перевести
    Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert an opening pick into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  7. Этот шаг не переведен. Помогите перевести
    Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place. Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components. Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components.
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components.
  8. Этот шаг не переведен. Помогите перевести
    Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive. Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel. Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  9. Этот шаг не переведен. Помогите перевести
    The top edge of the display is secured with both glue and clips. Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port. The clips will break if you use too much force. Work carefully and be patient.
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Again, don't insert the pick more than a few millimeters—about the width of the display bezel—or you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  10. Этот шаг не переведен. Помогите перевести
    Pull on the small nub on the suction cup to remove it from the front panel.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    • If you used an iSclack and it's still affixed to the iPhone, remove it now.
  11. Этот шаг не переведен. Помогите перевести
    Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board. As pictured, make sure the frame comes off with display and doesn't get stuck in the device.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • As pictured, make sure the frame comes off with display and doesn't get stuck in the device.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  12. Этот шаг не переведен. Помогите перевести
    • Remove five Y000 screws securing the logic board connector bracket, of the following lengths:
    • Three 1.1 mm screws
    • One 3.1 mm screw
    • One 3.7 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  13. Этот шаг не переведен. Помогите перевести
    Remove the bracket.
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  14. Этот шаг не переведен. Помогите перевести
    Use the point of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board. Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Use the point of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  15. Этот шаг не переведен. Помогите перевести
    Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector. Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  16. Этот шаг не переведен. Помогите перевести
    Use the point of a spudger or a fingernail to disconnect the OLED panel cable connector. To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Use the point of a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Этот шаг не переведен. Помогите перевести
    Use the point of a spudger to pry the digitizer cable connector up from its socket. This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • Use the point of a spudger to pry the digitizer cable connector up from its socket.
    • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  18. Этот шаг не переведен. Помогите перевести
    The front panel sensor assembly flex cable is lightly adhered in place. Carefully lift the cable until the adhesive separates. Carefully lift the cable until the adhesive separates.
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
  19. Этот шаг не переведен. Помогите перевести
    Remove the display assembly.
  20. Этот шаг не переведен. Помогите перевести
    Remove the 1.2 mm Y000 screw on the back of the display assembly, near the infrared camera port.
    • Remove the 1.2 mm Y000 screw on the back of the display assembly, near the infrared camera port.
  21. Этот шаг не переведен. Помогите перевести
    Beneath the screw you just removed lies a small metal grounding clip. If it didn't already come out along with the screw, remove it now. During reassembly, orient the clip as shown. Hold the clip in position while you install and tighten the screw. During reassembly, orient the clip as shown. Hold the clip in position while you install and tighten the screw.
    • Beneath the screw you just removed lies a small metal grounding clip. If it didn't already come out along with the screw, remove it now.
    • During reassembly, orient the clip as shown. Hold the clip in position while you install and tighten the screw.
  22. Этот шаг не переведен. Помогите перевести
    Remove two more Y000 screws securing the speaker/sensor assembly:
    • Remove two more Y000 screws securing the speaker/sensor assembly:
    • One 1.6 mm screw
    • One 1.3 mm screw
  23. Этот шаг не переведен. Помогите перевести
    The earpiece speaker is lightly adhered in place. Using a spudger, gently pry under the top edge of the speaker assembly, and flip it over—down and away from the top edge of the display.
    • The earpiece speaker is lightly adhered in place.
    • Using a spudger, gently pry under the top edge of the speaker assembly, and flip it over—down and away from the top edge of the display.
    • The speaker remains attached via a very thin flex cable. Be careful not to strain or damage the cable.
  24. Этот шаг не переведен. Помогите перевести
    Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
  25. Этот шаг не переведен. Помогите перевести
    Carefully slide the flat edge of your spudger underneath the flex cable below the microphone. Twist gently to separate the microphone, while being careful not to strain or damage the flex cable. If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
    • Carefully slide the flat edge of your spudger underneath the flex cable below the microphone.
    • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
    • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
  26. Этот шаг не переведен. Помогите перевести
    Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module. Gently wiggle and lift to separate the module from its notch in the front panel. It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
    • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
    • Gently wiggle and lift to separate the module from its notch in the front panel.
    • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
  27. Этот шаг не переведен. Помогите перевести
    Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display. The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
    • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
    • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
  28. Этот шаг не переведен. Помогите перевести
    If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below. If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier. During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
    • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
    • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
    • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
    • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
  29. Этот шаг не переведен. Помогите перевести
    Remove the earpiece speaker and front sensor assembly. During reassembly, check the position of the black plastic module containing these components: Proximity sensor
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
Финишная черта
76 участников успешно повторили данное руководство.
Adam O'Camb
Участник с: 11.04.2015
135 414 Репутация
Автор 392 руководств
Команда
iFixit Участник iFixit
Community
137 членов
Автор 16 052 руководств
Комментариев: 20
Is it possible to fix the ““Face ID Is Not Available” problem? There seems to be a problem with the TrueDepth camera. Thanks!
Alejandro D - Ответить
@alejandrod I’m afraid Face ID won’t work if this part is replaced. As stated in the introduction, this component is paired to the logic board from the factory (similar to the home button on earlier iPhones). Currently, if you need to replace this part, you’ll have to sacrifice Face ID, or else pay Apple directly to perform the repair. (They have a software calibration tool that pairs the new part to your phone to re-enable Face ID, but they don’t share it with anyone outside of Apple.)
Jeff Suovanen -
The flex cable was too bent, and now is broken. I’m going to buy another flex cable, but… Are there any ways to recover the Face ID functionality? Desoldering some components from the old one and weld them in the new flex cable?
Andrea Giacon - Ответить
Flex cables can be repaired by a skilled microsolderer. It’s not a DIY however. If it’s a phone you care about, you’ll want to find yourself a good repair shop with the right equipment and skills. Apple can also repair it, but they will most likely just charge you $279 to replace the entire screen.
Jeff Suovanen -
My proximity sensor is defective and puts my phone in a boot loop when connected. To replace that, would I need to use a skilled microsolderer to replace that?
oosaghae - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 89
За последние 7 дней: 802
За последние 30 дней: 3,440
За всё время: 122,894
