Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to correctly apply replacement battery adhesive strips for “L-shaped" iPhone batteries, including the dual-cell batteries in the iPhone X and XS Max, and the single-cell battery in the iPhone XS. Anytime you remove the battery, these strips must be replaced. The strips are easily damaged if not applied correctly, so you may want to have a spare set of strips on hand when following this guide for the first time.
These adhesive strips are different from those in prior-generation iPhones due to the presence of the wireless charging coil. The coil lies directly underneath the battery, which is secured with four adhesive strips that are contoured around the coil to avoid damaging it.
Before you begin, you should have removed the battery by following a guide like the ones linked below:
To replace the battery adhesive strips in a different model iPhone, use one of the following guides:
Выберете то, что вам нужно
Before you begin, it's a good idea to test-fit your new battery in the iPhone.
If your test-fit looks good, take the battery back out and place it face-down on your work surface (with the connector contacts facing up).
If you have a two-cell battery, make sure the cells are aligned as they would be when installed in the iPhone.
Peel off the blue plastic liner from your new set of adhesive strips, and discard it.
Double-check the orientation of the adhesive strips, and make sure your battery is still lying face-down (with the connector contacts facing up).
Carefully position the adhesive strips over the battery, and stick them in place as shown.
Use your fingers or a cloth to press the strips firmly into place on the battery.
Press in the center to adhere the black regulatory label to the battery as well.
Roll your fingertip along the edges of the battery to stick down the black pull tab at the end of each adhesive strip.
To reassemble your iPhone, return to the guide you used to remove the battery and follow the remaining steps in reverse order.
Remember to take your old battery to an R2 or e-Stewards certified recycler.
23 участников успешно повторили данное руководство.
