ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’Ρ‹Π±Π΅Ρ€Π΅Ρ‚Π΅ Ρ‚ΠΎ, Ρ‡Ρ‚ΠΎ Π²Π°ΠΌ Π½ΡƒΠΆΠ½ΠΎ
  1. iPhone XR Pentalobe Screws Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone XR Pentalobe Screws Replacement, Remove the pentalobe screws: step 1, image 2 of 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • There's a black rubber gasket just beneath the head on each pentalobe screw. For maximum protection against dust and liquid, check the condition of the gaskets or replace the screws during reassembly.
Π—Π°ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠ΅
6 участников ΡƒΡΠΏΠ΅ΡˆΠ½ΠΎ ΠΏΠΎΠ²Ρ‚ΠΎΡ€ΠΈΠ»ΠΈ Π΄Π°Π½Π½ΠΎΠ΅ руководство.
Adam O'Camb
Участник с: 11.04.2015
174Β 491 РСпутация
Автор 418 руководств
0 Comments
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 18
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 120
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 504
Π—Π° всё врСмя: 14,891
