iPhone XS Max Screen Replacement
Выберете то, что вам нужно
Видео обзор
  1. iPhone XS Max Screen Replacement, Pentalobe Screws: шаг 1, изображение 1 из 2 iPhone XS Max Screen Replacement, Pentalobe Screws: шаг 1, изображение 2 из 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone XS Max Screen Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone XS Max Screen Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone XS Max Screen Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone XS Max Screen Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone XS Max Screen Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone XS Max Screen Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone XS Max Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone XS Max Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone XS Max Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone XS Max Screen Replacement: шаг 5, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 5, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone XS Max Screen Replacement: шаг 6, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 6, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 6, изображение 3 из 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone XS Max Screen Replacement: шаг 7, изображение 1 из 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  8. iPhone XS Max Screen Replacement: шаг 8, изображение 1 из 2 iPhone XS Max Screen Replacement: шаг 8, изображение 2 из 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone XS Max Screen Replacement: шаг 9, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 9, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone XS Max Screen Replacement: шаг 10, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 10, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 10, изображение 3 из 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage the internal components.
  11. iPhone XS Max Screen Replacement, Screen information: шаг 11, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone XS Max Screen Replacement: шаг 12, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 12, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 12, изображение 3 из 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone XS Max Screen Replacement: шаг 13, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 13, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 13, изображение 3 из 3
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  14. iPhone XS Max Screen Replacement: шаг 14, изображение 1 из 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
    • If you used an iSclack and it's still affixed to the iPhone, remove it now.
  15. iPhone XS Max Screen Replacement: шаг 15, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 15, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    • Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
    • Two 1.1 mm screws
    • One 1.5 mm screw
    • One 3.7 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  16. iPhone XS Max Screen Replacement: шаг 17, изображение 1 из 1
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  17. iPhone XS Max Screen Replacement: шаг 18, изображение 1 из 2 iPhone XS Max Screen Replacement: шаг 18, изображение 2 из 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone XS Max Screen Replacement: шаг 19, изображение 1 из 2 iPhone XS Max Screen Replacement: шаг 19, изображение 2 из 2
    • Remove the three Y000 screws securing the display connector bracket:
    • Two 1.5 mm screws
    • One 1.1 mm screw
  19. iPhone XS Max Screen Replacement: шаг 20, изображение 1 из 1
  20. iPhone XS Max Screen Replacement: шаг 21, изображение 1 из 2 iPhone XS Max Screen Replacement: шаг 21, изображение 2 из 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  21. iPhone XS Max Screen Replacement: шаг 22, изображение 1 из 2 iPhone XS Max Screen Replacement: шаг 22, изображение 2 из 2
    • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone XS Max Screen Replacement: шаг 23, изображение 1 из 2 iPhone XS Max Screen Replacement: шаг 23, изображение 2 из 2
    • Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  23. iPhone XS Max Screen Replacement: шаг 24, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 24, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 24, изображение 3 из 3
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
  24. iPhone XS Max Screen Replacement: шаг 25, изображение 1 из 1
  25. iPhone XS Max Screen Replacement, Earpiece Speaker and Front Sensor Assembly: шаг 26, изображение 1 из 2 iPhone XS Max Screen Replacement, Earpiece Speaker and Front Sensor Assembly: шаг 26, изображение 2 из 2
    • Remove the three Y000 screws securing the speaker/sensor assembly:
    • One 1.4 mm screw
    • Two 1.5 mm screws
  26. iPhone XS Max Screen Replacement: шаг 27, изображение 1 из 2 iPhone XS Max Screen Replacement: шаг 27, изображение 2 из 2
    • The earpiece speaker is lightly adhered in place.
    • Using a spudger, gently pry under the top edge of the speaker assembly, and flip it over—down and away from the top edge of the display.
    • The speaker remains attached via a very thin ribbon cable. Be careful not to strain or damage the cable.
  27. iPhone XS Max Screen Replacement: шаг 28, изображение 1 из 1
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
  28. iPhone XS Max Screen Replacement: шаг 29, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 29, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 29, изображение 3 из 3
    • Carefully slide the edge of your opening pick underneath the flex cable below the microphone.
    • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
    • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
  29. iPhone XS Max Screen Replacement: шаг 30, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 30, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 30, изображение 3 из 3
    • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
    • Gently wiggle and lift to separate the module from its notch in the front panel.
    • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
  30. iPhone XS Max Screen Replacement: шаг 31, изображение 1 из 2 iPhone XS Max Screen Replacement: шаг 31, изображение 2 из 2
    • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
    • If the sensor does not wiggle free after a few seconds, apply more heat and try again.
    • The sensor remains attached to the rest of the sensor assembly via a very thin ribbon cable. Be careful not to strain or damage the cable.
  31. iPhone XS Max Screen Replacement: шаг 32, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 32, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 32, изображение 3 из 3
    • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
    • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
    • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
    • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
  32. iPhone XS Max Screen Replacement: шаг 33, изображение 1 из 3 iPhone XS Max Screen Replacement: шаг 33, изображение 2 из 3 iPhone XS Max Screen Replacement: шаг 33, изображение 3 из 3
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
Заключение
162 участников успешно повторили данное руководство.
Jeff Suovanen
Участник с: 08/06/13
409 626 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Community
141 членов
Автор 17 637 руководств
35 Комментариев
Nice guide. I could be wrong but for the first time in a while, changing a display on an Apple phone looks like it’s not anymore difficult than previous models.
John K
the-screen-savers.com
John Knirr - Ответить
If you remove the screen but then apply the same screen back on the phone, will True Tone still be disabled?
Onel Jimenez - Ответить
@onslivion Nope! It'll continue to work fine, so long as you didn’t damage anything.
Jeff Suovanen -
Hi i broke the Flex cable of the Part.
what i can do now.
is their some Parts for sale?
murtasa972 - Ответить
I just switched the screens from 2 phones and both are unresponsive, if put them back to its original logic board the work again, any idea why they dont work? both are original.
martinlpz0422 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 140
За последние 7 дней: 916
За последние 30 дней: 4,015
За всё время: 350,603
