iPod 1st Generation Scroll Wheel Replacement
Выберете то, что вам нужно
    1. iPod 1st Generation Scroll Wheel Replacement, Turn on the Hold switch: шаг 1, изображение 1 из 1
      • Before beginning, be sure to activate the iPod's Hold switch to prevent the device from accidentally turning on.
      Спросите у FixBot
      Добавить комментарий
    2. iPod 1st Generation Scroll Wheel Replacement, Cut a Strip of Tape: шаг 2, изображение 1 из 1
      • Cut a strip of tape, preferably duct tape, about 6-8 inches long. Make sure it's wide enough to be able to cover the entire surface area of the Scroll Wheel
      • It is possible to use other types of tapes, like packing tape or stitched Scotch tape side-by-side, although it may take a few extra attempts in later steps.
      Спросите у FixBot
    3. iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: шаг 3, изображение 1 из 3 iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: шаг 3, изображение 2 из 3 iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: шаг 3, изображение 3 из 3
      • Lay the iPod flat on a solid table, then lay the strip of tape flat onto the Scroll Wheel, then press down on the entire surface of the Scroll Wheel & center Select button.
      Спросите у FixBot
      • With one hand firmly grasping the iPod, pull the strip of tape upwards with your other to remove the Scroll Wheel from it's housing.
      • Be sure beforehand to slowly peel the tape off of the other buttons to prevent them from being pulled off as well, notably the Play/Pause button & the Menu button
      Спросите у FixBot
    4. iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: шаг 5, изображение 1 из 3 iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: шаг 5, изображение 2 из 3 iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: шаг 5, изображение 3 из 3
      • Simply peel off the Scroll Wheel & it's Select button from the strip of tape
      Спросите у FixBot
    5. iPod 1st Generation Scroll Wheel Replacement, Done: шаг 6, изображение 1 из 1
      • Congratulations! You've successfully removed the Scroll Wheel from your iPod 1st Gen.
      Спросите у FixBot
Заключение
To reassemble your device, put the main Scroll Wheel mechanism back in first, followed by the center Select button.
edoogg
Участник с: 09/30/21
133 Репутация
1 руководство автора
2 Комментарии к руководству
Very brutal and very effective.
Montary - Ответить Поделиться
Made me laugh of how rudimental it is but how effective it is, is like making a depilation to the iPod
Foxy the dj - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 63
За всё время: 1,164
