Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The shiny rear half of your iPod case.
Выберете то, что вам нужно
Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Continue to run the opening tool along the side of the case until all five tabs have been released.
Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
4 участников успешно повторили данное руководство.
2 Комментариев
According to this site: https://www.lifewire.com/history-ipod-cl.... The thickness of the various HD sizes is different.
“4 x 2.4 x 0.78 inches - 5 GB Model
4 x 2.4 x 0.72 inches - 10 GB Model
4 x 2.4 x 0.84 inches - 20 GB Model”
It makes some sense from other information I’ve read, but I don’t find any discussion of a thick and thin version. Is the back for the 20GB model thicker/deeper than the 10GB model? Thanks for another great guide.
no, the model is same. but 2gen is a little thicker than 1 gen. apple use diffrent types of rubber cushion to fits in it. if you want change a bigger disk, make sure there is enugh space for battery
张兴潼 -
