Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
No audio? Replace the headphone jack!
Выберете то, что вам нужно
Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should open easily.
Open the case like a book with the dock connector at the top, and lay the rear panel next to the front half of the iPod.
Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
Remove the 3 silver Philips screws securing the headphone jack to the rear panel.
Slide a spudger beneath the orange headphone jack cable and use it to pry the cable up from the rear panel.
11 участников успешно повторили данное руководство.
