iPod 4th Generation or Photo Rear Panel Replacement
Выберете то, что вам нужно
  1. iPod 4th Generation or Photo Rear Panel Replacement, Rear Panel: шаг 1, изображение 1 из 1
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
  2. iPod 4th Generation or Photo Rear Panel Replacement: шаг 2, изображение 1 из 3 iPod 4th Generation or Photo Rear Panel Replacement: шаг 2, изображение 2 из 3 iPod 4th Generation or Photo Rear Panel Replacement: шаг 2, изображение 3 из 3
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should easily open.
  3. iPod 4th Generation or Photo Rear Panel Replacement: шаг 3, изображение 1 из 1
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector edge at the top, and lay the rear panel next to the front half of the iPod.
  4. iPod 4th Generation or Photo Rear Panel Replacement: шаг 4, изображение 1 из 1
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • This ribbon cable is very fragile. If you are replacing the battery, you can choose to skip this step and keep the headphone jack connected to the motherboard. Prop and tape the rear case against a box to keep it in place. Be very careful not to strain the fragile headphone jack cable as you work.
  5. iPod 4th Generation or Photo Rear Panel Replacement, Rear Panel: шаг 5, изображение 1 из 1
    • Remove the 3 silver Philips screws securing the headphone jack to the rear panel.
  6. iPod 4th Generation or Photo Rear Panel Replacement: шаг 6, изображение 1 из 1
    • Lift the headphone jack assembly out of the iPod.
    • Rear panel remains.
Заключение
10 участников успешно повторили данное руководство.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 34
За всё время: 13,313
