iPod Classic Hard Drive Replacement
Выберете то, что вам нужно
    1. iPod Classic Hard Drive Replacement, Hard Drive: шаг 1, изображение 1 из 1
      • Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble.
      • Proceed with caution and the warning that you may significantly damage your iPod beyond its present condition. Also, you may want a few extra pairs of plastic opening tools during installation, as they are easy to ruin when opening the iPod. Have fun!
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Спросите у FixBot
      Добавить комментарий
    2. iPod Classic Hard Drive Replacement: шаг 2, изображение 1 из 1
      • Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
      • Insert a plastic opening tool into the seam between the front and back of the iPod.
      Спросите у FixBot
    3. iPod Classic Hard Drive Replacement: шаг 3, изображение 1 из 1
      • Insert another plastic opening tool into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools.
      Спросите у FixBot
    4. iPod Classic Hard Drive Replacement: шаг 4, изображение 1 из 1
      • At an angle, carefully insert a putty knife about 1/8 inch into the seam between the two opening tools.
      • There are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
      • Once the putty knife has cleared the lip of the rear panel, pivot the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the gap between the opening tools.
      Спросите у FixBot
    5. iPod Classic Hard Drive Replacement: шаг 5, изображение 1 из 1
      • Push with your fingers on the rear panel behind the putty knife to minimize bending. Slowly flex the putty knife, as shown in the picture, to ensure that most of the metal tabs on this side of the iPod are disengaged.
      • The theory behind this method is, rather than attempting to not bend the rear panel at all, to bend it in a favorable manner that allows you to easily restore it later. Therefore, any bend in the sides of the rear panel should be drawing the lip of the rear panel away from the iPod, rather than pushing out on the curved surface. This method also disengages as many of the side clips as possible.
      Спросите у FixBot
    6. iPod Classic Hard Drive Replacement: шаг 6, изображение 1 из 1
      • Remove the putty knife from the iPod and reinsert it closer to the corner of the iPod, using the same wiggle method as before.
      • If at all possible, do not bend the corner of the rear panel.
      Спросите у FixBot
    7. iPod Classic Hard Drive Replacement: шаг 7, изображение 1 из 1
      • Near the headphone jack, insert a plastic opening tool into the seam between the front and back of the iPod.
      • You may find it easier to carefully flex the putty knife downward in order to create more of a gap for the opening tool, but be sure not to bend the corner of the rear panel!
      Спросите у FixBot
    8. iPod Classic Hard Drive Replacement: шаг 8, изображение 1 из 1
      • Near the center of the display, carefully insert a metal spudger into the gap created by the plastic opening tool.
      • It is easy to create a noticeable bump in the rear panel here that is difficult to repair. When prying the tab free, try to have the metal spudger pivot on the edge of the rear panel rather than bending the rear panel outward.
      • Using the metal spudger, disengage the single clip on the top of the iPod.
      Спросите у FixBot
    9. iPod Classic Hard Drive Replacement: шаг 9, изображение 1 из 1
      • Near the other top corner, insert a plastic opening tool into the seam between the front and back of the iPod
      Спросите у FixBot
    10. iPod Classic Hard Drive Replacement: шаг 10, изображение 1 из 1
      • On the other side, insert a plastic opening tool into the seam between the front and back of the iPod.
      • You may find it easier to angle the opening tool stuck in the top corner in order to create a sufficient gap.
      Спросите у FixBot
    11. iPod Classic Hard Drive Replacement: шаг 11, изображение 1 из 1
      • Remove the opening tool from the top corner and insert it into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools (as done on the other side).
      Спросите у FixBot
    12. iPod Classic Hard Drive Replacement: шаг 12, изображение 1 из 1
      • Again, there are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
      • Once the putty knife has cleared the lip of the rear panel, angle the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the iPod via the gap between the plastic opening tools.
      • Push with your fingers on the rear panel behind the putty knife to minimize bending. Ever so slightly flex the putty knife to ensure that most of the metal tabs on this side of the iPod are disengaged.
      Спросите у FixBot
    13. iPod Classic Hard Drive Replacement: шаг 13, изображение 1 из 1
      • The metal clips near the corners are notorious for tenaciously gripping the front panel. It is necessary to disengage these clips in order to open the iPod.
      • Carefully insert a metal spudger into the area near the stubborn metal clip.
      Спросите у FixBot
    14. iPod Classic Hard Drive Replacement: шаг 14, изображение 1 из 1
      • Gently wiggle the metal spudger down so that it is all the way in the rear panel.
      Спросите у FixBot
    15. iPod Classic Hard Drive Replacement: шаг 15, изображение 1 из 1
      • Gently begin to disengage the clip from the front panel.
      Спросите у FixBot
    16. iPod Classic Hard Drive Replacement: шаг 16, изображение 1 из 1
      • Continue to push up on the front panel with the metal spudger until the metal clip releases.
      Спросите у FixBot
    17. iPod Classic Hard Drive Replacement: шаг 17, изображение 1 из 1
      • There are two ribbon cables connecting the rear panel to the rest of the iPod. In the following step, be careful not to damage these ribbon cables.
      • Grasp the front panel assembly with one hand and the rear panel with the other.
      • Take a deep breath!
      • Gently (GENTLY) disengage the remaining clips on the rear panel by pulling the tops of the front and rear panels away from each other (think of the bottom of the iPod as a hinge), taking great care not to damage the ribbon cables holding the two halves together.
      Спросите у FixBot
    18. iPod Classic Hard Drive Replacement: шаг 18, изображение 1 из 1
      • Use a spudger to slide up the connector holding the orange battery ribbon in place. You only need to lift the locking bar up about 2 mm to free the cable.
      • Slide the orange battery ribbon out of its connector.
      Спросите у FixBot
    19. iPod Classic Hard Drive Replacement: шаг 19, изображение 1 из 1
      • Place the rear panel next to the iPod, being careful not to strain the orange headphone jack cable.
      Спросите у FixBot
    20. iPod Classic Hard Drive Replacement: шаг 20, изображение 1 из 1
      • Lift the hard drive up with one hand so you can access the headphone jack ribbon beneath.
      • Use a spudger to flip up the plastic tab holding the headphone jack ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
      • Slide the orange headphone jack ribbon out of its connector.
      • The rear panel is now free from the iPod.
      Спросите у FixBot
    21. iPod Classic Hard Drive Replacement: шаг 21, изображение 1 из 1
      • Now to repair the damage caused by liberating the internal parts of the iPod Classic! It is highly likely that at least one of the metal clips in the lower case has been bent upward. These clips must all be pointing downward in order to reinstall the rear panel.
      Спросите у FixBot
    22. iPod Classic Hard Drive Replacement: шаг 22, изображение 1 из 1
      • Take the broad, flat side of the metal spudger and push the clip down, taking care not to tear the thin metal rail from the rear panel.
      • Be careful not to damage any of the headphone jack parts while shaping these clips!
      Спросите у FixBot
    23. iPod Classic Hard Drive Replacement: шаг 23, изображение 1 из 1
      • On a clean, hard surface, lay the rear panel on its side. Carefully but firmly push down on it, rolling the entire lip side back into its proper spot.
      • It may be necessary to do this multiple times in order to achieve optimal straightness on the sides. It is better to have the edges of the case pushed in slightly too far rather than not far enough, because the reseating of the front panel will bend the rear panel into its correct alignment.
      • Now that the rear panel is back to a beautiful condition, you can move on to repairing the iPod!
      Спросите у FixBot
    24. iPod Classic Hard Drive Replacement: шаг 24, изображение 1 из 1
      • Rotate the hard drive out of the framework and place it so that the connector is facing up.
      • Use a spudger to flip up the small black locking tab holding the orange hard drive ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
      Спросите у FixBot
    25. iPod Classic Hard Drive Replacement: шаг 25, изображение 1 из 1
      • Slide the orange hard drive ribbon cable directly out of its connector.
      • If you are replacing the hard drive in your iPod and it did not come with the rubber mounting brackets and foam padding, transfer these items from your old drive to the replacement drive.
      Спросите у FixBot
Заключение
Before you snap the case shut, be sure to test the device to ensure that it's working properly.
337 человек успешно провели ремонт по этому руководству.
iRobot
Участник с: 09/24/09
1 Репутация
Автор 632 руководств
51 Комментарии к руководству
The instructions worked like a charm. This is not for the faint of heart and requires some modicum of skill, but I saved a buttload of money by doing it myself. You will definitely need the recommended tools.
johannesdecruce - Ответить Поделиться
It worked like a charm... Just need to follow the instructions carefully and you can avoid to spend 200 something € to buy a new iPod!
Thanks iFixit
Fanny Millon - Ответить Поделиться
i couldn't get the plastic opening tool in between the 2 sections. i ended up using two razor blades instead of the plastic tools and the putty knife, i was able to replace the hard drive with very little struggle and almost no cosmetic damage(not that i care what the thing looks like)
algore2016 - Ответить Поделиться
Thanks for a highly useful guide. Slowly and methodically, using a single-bladed, razor blade, I was able to open the case, following this procedure. Patience is, indeed, a virtue, in this case.
I was able to successfully replace the hard drive and battery.
The only snag I encountered was that the headphone jack ribbon was glued to circuit board adjacent to the connector under the hard drive. (I just left this ribbon be, not wanting to risk damaging the ribbon.) It was a bit awkward straightening the case edges, but I managed.
Overall, I'd give this guide a grade of "A"....it was nearly perfect and very clear. Bravo!
rgstout - Ответить Поделиться
Well I managed to get it apart, though it wasn't all that difficult with the right tools, but getting it back together has been a nightmare. Just saying "reverse the process" is reall not quite enough in this case. All the little pieces of shock padding keep falling off, it's almost impossible to get the two wires plugged back in as well as keeping them in place, but I got there in the end. Or so I thought . Now my ipod has no sound (except from dock output) - and on investigating I find I have severed the orange cable near the jack itself- either by bending it or catching it on something. So another part to buy. So it's a warning to be very careful.
James Skilton - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 79
За последние 7 дней: 390
За последние 30 дней: 1,659
За всё время: 867,265
