Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Инструмент, используемый на этом этапе:Jimmy$7.95-
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
Use a spudger or the tip of your finger to carefully disconnect the orange click wheel ribbon from the logic board.
Remove the two #00 Phillips screws securing the headphone jack to the casing.
Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
Lift the battery off of the logic board and lay it to the side of the iPod.
Use a spudger or the tip of your finger to carefully disconect the orange hard drive ribbon from the logic board.
121 участников успешно повторили данное руководство.
25 Комментариев
I have been tinkering with the iPod classics, the 5th gens and now the iPod minis. I think the minis have a cool form factor and the plug and play for a compact flash card is handy. I have purchased a compact flash adapter to SD card, I then put a 128GB microsd into an SD to micro adapter and now I have 128GB mini. As a note, I did have to format the new card to FAT32 with AOMEI prior iPod restore.
Hello good sir i unfortunately speakn't good english but i try best now .. having a good day are you… i am also have a service and for fixing ipods … if you want i will give it too you send me an email albertogeniusipodfixes@gmail.com
can i change the type of hard disk
Yes www.iflash.xyz has good stuff for these or u can just use a CF Card and it'll be Plug N Play…literally
