iPod Nano 5th Generation Glass Panel Replacement
Выберете то, что вам нужно
  1. iPod Nano 5th Generation Glass Panel Replacement, Glass Panel: шаг 1, изображение 1 из 3 iPod Nano 5th Generation Glass Panel Replacement, Glass Panel: шаг 1, изображение 2 из 3 iPod Nano 5th Generation Glass Panel Replacement, Glass Panel: шаг 1, изображение 3 из 3
    • Insert an iPod opening tool between the outer case and top bezel near the screen.
    • Lifting up on the iPod opening tool, gently pry the top panel off of the device.
    • The bezel is attached with adhesive, and may require some force to remove.
  2. iPod Nano 5th Generation Glass Panel Replacement: шаг 2, изображение 1 из 1
    • Use an iPod opening tool to pry the hold switch button off of the hold switch plate.
  3. iPod Nano 5th Generation Glass Panel Replacement: шаг 3, изображение 1 из 1
    • Remove the two 3.2 mm screws.
    • These screws are angled toward the outer case and are also very small. Use a sharp screwdriver and be careful not to strip the screws.
  4. iPod Nano 5th Generation Glass Panel Replacement: шаг 4, изображение 1 из 1
    • Insert an iPod opening tool between the outer case and the metal hold switch plate near the top of the screen .
    • While slightly lifting up on the iPod opening tool, pull the hold switch plate out of the iPod.
    • The hold switch plate is still attached to iPod by a very thin, very fragile ribbon cable. Be careful not to break it.
  5. iPod Nano 5th Generation Glass Panel Replacement: шаг 5, изображение 1 из 2 iPod Nano 5th Generation Glass Panel Replacement: шаг 5, изображение 2 из 2
    • The glass panel is held in place by adhesive on all four sides. In the following steps, work carefully to avoid cracking the glass.
    • Insert an iPod opening tool between the display and the glass panel at the top of the device.
    • Rotate the iPod opening tool towards the rear of the device, slightly lifting the top of the glass out of the outer case.
    • The glass panel does not raise very far. Do not attempt to completely remove the panel yet, or you are likely to break the display screen.
  6. iPod Nano 5th Generation Glass Panel Replacement: шаг 6, изображение 1 из 1
    • While lifting the screen up with one iPod opening tool, insert a second iPod opening tool in between the outer case and the top left edge of the glass panel.
    • Remove the first iPod opening tool from between the glass and LCD in the top of the device.
  7. iPod Nano 5th Generation Glass Panel Replacement: шаг 7, изображение 1 из 2 iPod Nano 5th Generation Glass Panel Replacement: шаг 7, изображение 2 из 2
    • Prying up slightly on the iPod opening tool, insert a second iPod opening tool in between the front glass and the outer case, on the right side of the screen.
    • Slide the second iPod opening tool along the right edge of the panel to remove the adhesive.
  8. iPod Nano 5th Generation Glass Panel Replacement: шаг 8, изображение 1 из 2 iPod Nano 5th Generation Glass Panel Replacement: шаг 8, изображение 2 из 2
    • With one iPod opening tool still between the glass and outer case, insert a second iPod opening tool in between the front glass and outer case, on the left side.
    • Slide the second iPod opening tool toward the bottom of the device to remove the adhesive.
  9. iPod Nano 5th Generation Glass Panel Replacement: шаг 9, изображение 1 из 1
    • Lifting the glass from the side nearest the top of the iPod, remove the glass panel from the Nano.
Заключение
36 участников успешно повторили данное руководство.
Matthew Newsom
Участник с: 01/05/10
39 500 Репутация
Автор 67 руководств
6 Комментариев
If the glass is cracked, you may not have to remove the end of the ipod to pry out the glass. In my case, I was able to carefully (with out putting pressure on the screen below) get the glass out in pieces.
tony1 - Ответить
This step by step guide is perfect for replacing the glass! There is no need to remove the click-wheel or the camera bezel - as seen in may other videos and guides. So stay away from the click wheel if you can - it's just glued in (there is no snap!) and it's really hard to put back in place again. And yes, ideally you can remove the glass without opening anything. It is just glued in and the new one will go in from the top. Good Luck!
Stefan Georgi - Ответить
I gave my homie my 8 gig when i bought my 16 gig. his girl dropped it and the glass screen cracked. took me no more then 5 minutes and i had it as good as new! Whoop Whoop, danke fo the instructions!
steven - Ответить
Dear Steven, To me exactly the same happened, although I was the person who got the Ipod and dropped it. So I do understand how to get the glass out, but how do I put a new one in? Just insert it and put everything back on? Should I use glue when I put the screen in? Or will it just stay there on its own? Thanks!
myrthe569 -
this was great and super easy! thanks so much
solinvictusetc - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 18
За последние 30 дней: 62
За всё время: 46,475
