Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to remove your Nano's belt clip.
  1. Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
    • Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
    • Be careful not to overheat the front panel assembly, as it may result in damage to the LCD.
  2. While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
    • While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
    • Do not attempt to pry out the front panel assembly from, or insert the opening tool into the left side of the display, as the display data cable is right underneath and may be damaged in the process.
    • Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
    • If the front panel is excessively difficult to lift out of the outer case, reheat the area and try again.
  3. Lift the front panel assembly from the headphone jack side of the Nano. Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
    • Lift the front panel assembly from the headphone jack side of the Nano.
    • Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
    • The front panel assembly is still attached to the Nano by two cables.
  4. Lay the front panel assembly next to the Nano.
    • Lay the front panel assembly next to the Nano.
    • Remove the following two screws:
    • One 2.3 mm Phillips screw
    • One 2.6 mm shouldered Phillips screw
  5. Use an iPod opening tool to pry the steel shield out of the Nano by its upper right corner. Remove the steel shield from the Nano.
    • Use an iPod opening tool to pry the steel shield out of the Nano by its upper right corner.
    • Remove the steel shield from the Nano.
  6. Use an iPod opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board. Use an iPod opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
    • Use an iPod opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
  7. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Remove the front panel assembly, minding its two cables that may get caught. To reassemble, you can use the double-sided tape found here.
    • Remove the front panel assembly, minding its two cables that may get caught. To reassemble, you can use the double-sided tape found here.
  9. Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
    • Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
  10. Remove the single 1.9 mm Phillips screw securing the logic board to the outer case.
    • Remove the single 1.9 mm Phillips screw securing the logic board to the outer case.
  11. Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case. The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
    • Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case.
    • The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
    • Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
  12. Use an iPod opening tool to gently pry the logic board off the adhesive holding it against the outer case.
    • Use an iPod opening tool to gently pry the logic board off the adhesive holding it against the outer case.
    • Do not excessively pry the logic board upward.
  13. Use your iPod opening tool to gently push the dock connector toward the center of the Nano. Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
    • Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
    • Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
  14. Remove the following five screws:
    • Remove the following five screws:
    • One 1.7 mm Phillips screw
    • Four 3.9 mm Phillips screws.
  15. Use a pair of tweezers to carefully pull the headphone jack toward the center of the Nano. Avoid pulling on the cable, as it is very thin and delicate. The plastic mounting ear is a safer area to pull on.
    • Use a pair of tweezers to carefully pull the headphone jack toward the center of the Nano.
    • Avoid pulling on the cable, as it is very thin and delicate. The plastic mounting ear is a safer area to pull on.
  16. Very carefully pull the headphone jack assembly ribbon cable toward the dock connector to separate the sleep and volume buttons from the outer case. Remove the headphone jack assembly.
    • Very carefully pull the headphone jack assembly ribbon cable toward the dock connector to separate the sleep and volume buttons from the outer case.
    • Remove the headphone jack assembly.
  17. Remove the following three screws:
    • Remove the following three screws:
    • One black 1.8 mm Phillips screw
    • Two 1.7 mm Phillips screws
  18. Remove the clip from the outer case.
    • Remove the clip from the outer case.
    • When reinstalling the clip, it is necessary to squeeze the base of the clip very tightly against the outer case as you insert the first screw.
Заключение
23 участников успешно повторили данное руководство.
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 70
За всё время: 85,148
