Введение
This guide will walk you through the instructions for replacing the Bluetooth antenna on a 7th Gen iPod Nano.
Запчасти
Детали не указаны.
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
Insert a spudger under the cover, then pry it up and away from the device.
Remove the rear plastic cover from the iPod.
Insert a plastic opening tool into the seam between the white plastic front panel and the rear case.
Slide the opening tool along the edge of the front panel to free it from clips and adhesive.
Use a metal spudger to carefully pry near the Lightning connector and under all parts of the front panel assembly: the front glass/digitizer, the LCD display and the metal midframe.
Continue prying along the edges under the front panel assembly, releasing the clips and adhesive along the sides of the device.
Use a spudger to release the digitizer cable and display data cable connectors.
Remove the 1.4 mm Phillips #000 screw from the antenna cable.
Release the Bluetooth antenna connector cable with a spudger.
Remove the antenna from the device.
2 участников успешно повторили данное руководство.
Комментариев: 2
Upset that iFixit doesn’t hold this part (the bluetooth antenna) in their inventory, especially because it’s so easy to break when opening the device.
