Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to replace a broken or faulty LCD display in your 7th Generation iPod Nano.
  1. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    which temperature must be used for heating? Thx
    fbarletta - Ответить
    I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
    By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
    Fredrik -
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - Ответить
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - Ответить
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - Ответить
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - Ответить
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - Ответить
    Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
    Esmond Pitt - Ответить
    My microwave just died, can i heat it with boiled water?
    Alex COLOMBANI - Ответить
    Taping as shown is impractical when using hair dryer method—tape simply comes off in the heat and gets in way of getting out the shards on the sides. If the thing wasn’t shattered, then taping unnecessary.
    B. A. Computer Services - Ответить
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - Ответить
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - Ответить
    The “Galaxy S8 Replacement Battery” that you are selling with the kit is the wrong battery, the one that you are selling is a 3000mAh (which is the wrong amperage) as the OEM Samsung Galaxy S8 battery is “Model #: EB-BG892ABA / 4000mAh / Normal Voltage: 3.85V / Charge Voltage: 4.4V / A/S: 1588-3366 4000mAh 15.0Wh
    stevengenat - Ответить
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - Ответить
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - Ответить
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - Ответить
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - Ответить
    I’ve tried for 2 days and cannot get this to work. I should have just taken it to my local iphone fixit shop. This is a frustrating purchase to say the least.
    jeffrey hill - Ответить
    Step 1 should be: now that you have looked over the tools of this repair kit, take your ipad to the nearest repair store and let them handle it. Sure you will waste about $65 by purchasing this kit and the cost of the repair but you will not tear your ipad up and you will have at least 2 days of your life that you can spend time with your family.
    Just replaced the battery in my iPad mini LTE. Followed the Ifix step by step instructions and they worked very well. The only thing i would change is step 42. You do not have to lift the LCD connector from the logic board. So don’t. It’s an unnecessary step. Other then that all was good. It took me about 2 1/2 hours from start to finish but I took my time and I recommend you take your time also. Very exciting too finish doing it and see it come to life afterwards. Tested everything and everything still works
    Anybody want to buy my iFix battery replacement tool kit only used once cheap?
    kaplang - Ответить
    i opener sucks! it’s incapable of heating factory glue enough to take a sealed phone apart and caused my backglass to shatter. i removed it the rest of the way with a soldering iron!
    Elijah Marvin - Ответить
    You should, at least, mention which wattage is used for the 30 seconds heating - 750 isn’t enough, obviously. Display shatterered . Thanks.
    dr_baeschtlr - Ответить
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - Ответить
    At what power (how many watts) does the 30 seconds apply?
    Jarl Friis - Ответить
  2. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
    yamayhuang - Ответить
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - Ответить
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - Ответить
    I don't own a microwave.
    mdanihy - Ответить
    Its again waterproof when you change iphone 7 battery?
    Jon - Ответить
    I don't have a microwave???
    Joe Blow - Ответить
    30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
    Sam Stieg - Ответить
    can i use just ordinary microwave???
    juneseok kwon - Ответить
    If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
    Mohideen Rifay - Ответить
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - Ответить
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - Ответить
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - Ответить
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - Ответить
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - Ответить
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - Ответить
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - Ответить
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - Ответить
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - Ответить
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - Ответить
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - Ответить
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Rapp -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
  3. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Will a hair dryer work for heating the glass?
    Me berg - Ответить
    Can you use an oven instead?
    Rafael -
    Yes, as does a heat gun.
    anonymous 4602 - Ответить
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - Ответить
    microwave on WHAT WATTAGE ??? 100 W OR 1600 W ??? NOT THE SAME
    Ivor Pocrnja - Ответить
    This was not easy. I finally got a pick under the glass of my moto x4 phone after placing my phone on my kitchen hot plate and letting the hot plate go up to about 160F—measuring with a candy thermometer. I was scared of it(either the phone or the iopener) getting too hot—I checked in with another online video and saw they used a 100C heat gun for 2 min on the left side: When I figured that was 212F I got braver with heating the phone.—My screen and display were already broken. I can’t say exactly how long the phone was on the hot plate at 150-160 because the hotplate annoyingly goes on and off not sustaining a stable temperatureprobably a few
    Nahariyah Mosenkis - Ответить
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - Ответить
  4. Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel. Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
    • Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
  5. Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger. Insert a spudger under the cover, then pry it up and away from the device. Remove the rear plastic cover from the iPod.
    • Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
    • Insert a spudger under the cover, then pry it up and away from the device.
    • Remove the rear plastic cover from the iPod.
    • Be very careful in removing the plastic cover as the bluetooth antenna is adhered to it.
    Too bad there is not a warning for bluetooth antenna damage... This guide led me to tearing my antenna.
    trogfield - Ответить
  6. Gently bend the Bluetooth antenna to the right, out of the way of the screws in the bottom of the device.
    • Gently bend the Bluetooth antenna to the right, out of the way of the screws in the bottom of the device.
    • Remove the single 1.4 mm Phillips #000 screw from the black plastic spacer.
  7. Use a plastic opening tool to remove the black plastic spacer from the Nano. Use a plastic opening tool to remove the black plastic spacer from the Nano.
    • Use a plastic opening tool to remove the black plastic spacer from the Nano.
  8. Remove the two 2 mm Phillips #000 screws from the bottom of the case.
    • Remove the two 2 mm Phillips #000 screws from the bottom of the case.
  9. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  10. Insert a plastic opening tool into the seam between the white plastic front panel and the rear case. Slide the opening tool along the edge of the front panel to free it from clips and adhesive.
    • Insert a plastic opening tool into the seam between the white plastic front panel and the rear case.
    • Slide the opening tool along the edge of the front panel to free it from clips and adhesive.
  11. Use a spudger to press the midframe screw tab up and out of the rear case.
    • Use a spudger to press the midframe screw tab up and out of the rear case.
  12. Use a metal spudger to carefully pry near the Lightning connector and under all parts of the front panel assembly: the front glass/digitizer, the LCD display and the metal midframe.
    • Use a metal spudger to carefully pry near the Lightning connector and under all parts of the front panel assembly: the front glass/digitizer, the LCD display and the metal midframe.
    • The adhesive under the metal midframe/display assembly is quite strong and the components are fragile, so go slowly and gently. Make sure you do not bend the LCD screen.
    This step is extremely difficult to do... How am I supposed to manage to lift the frame with the LCD screen without potentially causing damage to the LCD screen?
    Uriel Melchor - Ответить
    Yeah, I did run into a roadblock with that too, so I’ll have to find a heat gun (or iOpener) and see if I can use that to loosen the frame.
    Kevin Bhasi -
    Hello, My name is Michael , in this moment I destroyed one of the lines of the screen, because in this point every connector it is the right side , so I advice start for the another side , left up through right down side i think is the better way.
    it is the shame for me.
    Michael Lendian Castillo - Ответить
  13. Continue prying along the edges under the front panel assembly, releasing the clips and adhesive along the sides of the device. Continue prying along the edges under the front panel assembly, releasing the clips and adhesive along the sides of the device.
    • Continue prying along the edges under the front panel assembly, releasing the clips and adhesive along the sides of the device.
  14. Pull the front panel assembly slightly down and partially out of the device. You only need to open the device enough to gain access to the display cable connectors near the sleep/power button.
    • Pull the front panel assembly slightly down and partially out of the device.
    • You only need to open the device enough to gain access to the display cable connectors near the sleep/power button.
    • Do not separate the two halves entirely, they are still connected by several cables.
    STOP! DO NOT ATTEMPT THIS UNTIL AFTER STEP 14 IF YOU VALUE NOT SEVERING THE LCD CABLE! Just please, please be aware that the battery cable CANNOT be disconnected, be careful!
    Colin Gubler - Ответить
  15. Use a spudger to release the digitizer cable and display data cable connectors. Use a spudger to release the digitizer cable and display data cable connectors.
    • Use a spudger to release the digitizer cable and display data cable connectors.
  16. Gently unfold the two halves of the device to access the internal components.
    • Gently unfold the two halves of the device to access the internal components.
    • Do not try to completely separate the two sections, yet, as they are still attached via a soldered cable.
  17. Pull up on the battery pull tab to free the battery from its adhesive. Flip the battery over into the rear case for safekeeping.
    • Pull up on the battery pull tab to free the battery from its adhesive.
    • Flip the battery over into the rear case for safekeeping.
    Disconnecting the battery from the lcd screen can ruin the battery,
    so why do that if you are just replacing the digitizer?
    rather just open the six screws and disconnect the digitizer.
    Yehuda Tsibushkin - Ответить
  18. Completely separate the front panel assembly from the rest of the device.
    • Completely separate the front panel assembly from the rest of the device.
  19. Insert a spudger under the metal midframe and display on the left side of the home button. Make sure that the spudger is under the entire display assembly to prevent bending the metal midframe.
    • Insert a spudger under the metal midframe and display on the left side of the home button.
    • Make sure that the spudger is under the entire display assembly to prevent bending the metal midframe.
    • Rotate the spudger around the home button and across the front panel, releasing the adhesive holding the display in place.
    Is not easier to remove the LCD first from the metal midframe?
    I think this will prevent any damage to the LCD while trying to release adhesive around the home button and and the metal midframe
    rallenfl - Ответить
    I am trying to put it my LCD back on my dgitizer and there is a wire on the digitizer and i cant figure out witch way to bend it.
    Scott P. - Ответить
    esta es la manera dificil de hacerlo. Para que quitar el marco metalico del touch?
    Andreu Bonafonte - Ответить
  20. Once all of the adhesive has been released, gently separate the display assembly from the front glass/digitizer.
    • Once all of the adhesive has been released, gently separate the display assembly from the front glass/digitizer.
  21. Remove the six (three on each side) 1.5 mm Phillips #000 screws securing the metal midframe to the display. Remove the six (three on each side) 1.5 mm Phillips #000 screws securing the metal midframe to the display.
    • Remove the six (three on each side) 1.5 mm Phillips #000 screws securing the metal midframe to the display.
  22. If there is tape holding the midframe to the display, remove it with a plastic opening tool.
    • If there is tape holding the midframe to the display, remove it with a plastic opening tool.
  23. Remove the display from the midframe.
    • Remove the display from the midframe.
Заключение
33 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 18.10.2012
417 965 Репутация
Автор 547 руководств
Команда
iFixit Участник iFixit
Community
129 членов
Автор 12 526 руководств
Комментариев: 2
My display didn’t come out intact, so I ordered a new one but it has no metal backing. Where could I get it?
Liam Powell - Ответить
Love the guide. In performing this myself very useful, but there are may small details that would have helped me and for the first time novice such as:
- Describing in more detail how to separate the Digitizer and Display cables that intertwine and is connected to the home button.
- Recommend repair novice taking their own pictures as reference points to go back to
- Tools a good magnifying lens or a means to see small part details
- Provide more insight on how the display metal back is to be removed after folding back display cables and removing corner tape.
- Not all repair parts are the same; recommend basic instruction on common steps for parts that require re-applying the metal back, and folding over the cables
All-in-all a good guide…Thanks.
James - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 92
За последние 30 дней: 470
За всё время: 64,356
