Введение
The internal metal stiffening frame.
Выберете то, что вам нужно
The following step can be challenging and time consuming. Be sure to go slowly and have patience to prevent damaging your iPod.
Use an Exacto knife to separate the glue holding the USB port on the iPod. Run the knife along the seam between the two sections of the iPod until the glue is separated. Expect to run the knife along this edge 20-30 times before the glue will be entirely freed.
Continue to run the knife around all four edges of the USB port until the glue is released. You may be able to gently wiggle the knife from side to side to help release the glue.
Use a spudger to push on the headphone jack and slide the USB port out of its housing.
After the USB port comes free, carefully slide it out of its housing. Don't pull it out too far because there's still a ribbon cable connecting it to the logic board.
Continue to slide the iPod out of its casing by using a spudger to push on the logic board near the headphone jack.
Turn the iPod so that the click wheel is facing up. This will prevent the battery indicator from falling out.
Slide the iPod out of its casing.
Use a spudger to flip up the black plastic tab holding the USB port ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the USB ribbon out of its connector.
Lift the USB port and detached ribbon cable out of the iPod.
Gently pull back the white plastic framework to free the left edge of the logic board. Pull up on the logic board slightly to prevent the logic board from falling back into place.
Repeat the same procedure on the opposite side to free the logic board from the white plastic casing.
Lift the logic board up to disconnect it from the memory board beneath. Don't remove the logic board from the iPod yet, because it's still connected to the battery.
Turn the iPod over and use your finger to push the battery through the hole in the casing. The battery is attached to the plastic framework with a mild adhesive.
Lift the battery and logic board out of the iPod.
Peel up the translucent tape securing the memory board to the edge of the white plastic framework. It is only necessary to peel up the tape on one side, as the other side will be freed while removing the memory board.
Lift the memory board out of the framework and peel the tape off the other side of the framework.
2 человек успешно провели ремонт по этому руководству.
