Введение
Replace the damaged headphone jack to hear those sweet tunes again.
Выберете то, что вам нужно
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
Pry the rear case away from the front case.
Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
Peel the battery up from the front case with an iPod opening tool.
Remove the logic board and battery from the iPod.
Pry the headphone jack from the front case with an iPod opening tool.
Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
Еще один человек закончил это руководство.
