Введение
This guide shows how to replace the rear panel on the 2nd Generation iPod Touch.
Выберете то, что вам нужно
The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
Gently insert a plastic opening tool, near the volume control buttons, between the plastic surround of the screen and the metal case.
Rotate the tool away from the Touch to pry up on the glass panel.
Insert the plastic opening tool between the front panel and its plastic surround and pry up at several points along the left edge of the Touch.
Continue prying up the left edge until the top and bottom edges start to lift out of the Touch.
Once the top and bottom edges have lifted slightly out of the Touch, use the opening tool to assure the plastic surround is detached from the clips along the inside of the Touch.
Continue the prying procedure, now focusing on detaching the plastic surround from the internal metal clips.
Pry along the top edge of the Touch to further separate the front panel from the rest of the device.
Pry up the front panel along the right edge using the method described in previous steps.
Eventually work around the entire perimeter of the front panel until it is lifted slightly from the rear panel.
Lift the front panel out of the rear case minding the cable still attaching it near the upper left corner of the Touch.
Use the flat end of a spudger (or an opening tool) to pry the touch screen cable connector up off the upper logic board.
Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
Pry up along the lower edge of the display enough to grab it with your fingers.
Lift the display up from its lower edge and rotate it toward the top of the Touch.
While holding the display with one hand, run an iPod opening tool down the two long edges of the mylar reflector attached to the metal display tray.
When it is sufficiently free from the display tray, remove the mylar reflector from the Touch.
Remove the seven Phillips screws securing the metal display tray to the rear panel.
Lay the display back down into its tray.
Remove the final Phillips screw securing the metal tray to the rear panel.
Lift the display out of the metal tray and rotate it toward the top edge of the Touch.
Use an iPod opening tool to lift the metal display tray and rotate it up toward the top edge of the Touch.
Use the edge of an iPod opening tool to peel the copper tape off the top edge of the display.
Use an iPod opening tool to pry the display cable connector up off its socket on the logic board.
Lift the metal display tray slightly (the battery is attached to its underside) and remove the display from the Touch, minding its delicate cable that may get caught.
Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
Remove the metal display tray and set it aside.
Lay the battery flat in the rear panel.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the single Phillips screw securing the gold pressure contact to the logic board.
Use a pair of tweezers to lift the Phillips screw out of the logic board.
Remove the following three Phillips screws securing the logic board to the rear panel:
One 1.9 mm screw
Two 2.3 mm screws
Using the tip of a spudger, flip up the control button ribbon cable retaining flap.
Use a pair of tweezers to pull the control button ribbon cable straight out of its socket.
Use the tip of a spudger to peel back the protective rubber grommet to reveal a hidden Phillips screw.
Remove the hidden Phillips screw.
Remove the two remaining Phillips screws securing the upper logic board to the rear panel.
Use the flat end of a spudger to separate the Wi-Fi ribbon cable from the adhesive securing it to the rear panel.
Insert the flat end of a spudger between the metal rear panel and Wi-Fi ribbon cable to further loosen the adhesive along the length of the cable.
Pull the small upper portion of the logic board away from the top edge of the Touch to separate it from the rear panel.
Allow the board to rest on the outside of the rear panel.
Gently pull the lower portion of the logic board away from the bottom edge of the rear panel.
Carefully lift the logic board assembly out of the rear case, minding any edges that may get caught.
Remove the two Phillips screws securing the power/volume controls to the rear panel.
Use the tip of a spudger to remove the yellow kapton tape covering the power/volume control ribbon cable.
Lift the power/volume controls out of the rear panel.
Use your finger to push the plastic antenna window through the other side of the rear panel.
Remove the plastic antenna window from the rear panel.
Use the flat end of a spudger to pry the protective rubber grommet from the bottom left hand corner of the rear panel.
21 человек успешно провели ремонт по этому руководству.
