Введение
Restore life to your iPod Touch 3rd Generation by replacing the logic board.
Выберете то, что вам нужно
The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
Gently insert an iPod opening tool between the glass front panel and its plastic surround near the volume adjust buttons.
Rotate the tool away from the Touch to pry up on the glass panel.
Insert the iPod opening tool between the front panel and its plastic surround and pry up at several points along the left edge of the Touch.
Continue prying up the left edge until the top and bottom edges start to lift out of the Touch.
Once the top and bottom edges have lifted slightly out of the Touch, use the opening tool to assure the plastic surround is detached from the clips along the inside of the Touch.
Continue the prying procedure, now focusing on detaching the plastic surround from the internal metal clips.
Pry along the top edge of the Touch to further separate the front panel from the rest of the device.
Pry up the front panel along the right edge using the method described in previous steps.
Eventually work around the entire perimeter of the front panel until it is lifted slightly from the rear panel.
Lift the front panel out of the rear case minding the cable still attaching it near the upper left corner of the Touch.
Use the flat end of a spudger (or an opening tool) to very carefully pry the touch screen cable connector up off the upper logic board.
Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
Pry up along the lower edge of the display enough to grab it with your fingers, being careful to not flex the screen.
Lift the display up from its lower edge and rotate it toward the top of the Touch.
Remove the seven Phillips screws securing the metal display tray to the rear panel. They may be very tight; watch carefully to make sure you don't strip them.
Lay the display back down into its tray.
Remove the final Phillips screw securing the metal tray to the rear panel.
Lift the display out of the metal tray and rotate it toward the top edge of the Touch.
Use an iPod opening tool to lift the metal display tray and rotate it up toward the top edge of the Touch.
Use the edge of an iPod opening tool to peel the copper tape off the top edge of the display.
Use the edge of an iPod opening tool to remove the piece of tape covering the display data cable.
Use an iPod opening tool to pry the display data cable connector up off its socket on the logic board.
Lift the metal display tray slightly (the battery is attached to its underside) and remove the display from the Touch, minding its delicate cable that may get caught.
Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
Remove the metal display tray and set it aside.
Lay the battery flat in the rear panel.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the single Phillips screw securing the gold pressure contact to the logic board.
Use a pair of tweezers to lift the Phillips screw out of the logic board.
Remove the following three Phillips screws securing the logic board to the rear panel:
Two 2.3 mm screws
One 1.9 mm screw
Using the edge of an iPod opening tool, flip up the control button ribbon cable retaining flap.
Carefully remove the two large pieces of tape securing the ribbon cables to the rear panel.
Use the edge of an iPod opening tool to peel back the protective rubber grommet to reveal a hidden Phillips screw.
Remove the hidden Phillips screw.
Remove the remaining Phillips screw securing the upper logic board to the rear panel.
Carefully pull the lower logic board away from the lower edge of the rear panel.
Use the edge of an iPod opening tool to carefully free the antenna connector cable from the adhesive securing it to the rear case.
Use the edge of your iPod opening tool to disconnect the antenna cable.
Carefully peel the antenna cable off the adhesive securing it to the rear panel.
Remove the small strip of tape securing the antenna socket ribbon cable to the rear panel.
Use the edge of an iPod opening tool to peel the antenna socket ribbon cable off the rear panel.
Use the edge of an iPod opening tool to carefully peel the Wi-Fi ribbon cable off the adhesive securing it to the rear panel.
Use an iPod opening tool to pry the black plastic frame under the upper logic board up from the adhesive securing it to the rear panel.
Carefully remove the logic board assembly from the rear panel, minding any cables that may get caught.
23 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
is there a way to repair the headphone jack?
mine only gives out a tiny bit of the frequency response, no bass or treble at all, and i can tell it's probably the ribbon cable.
