iPod Touch 5th Generation LCD Shield Plate Replacement
Выберете то, что вам нужно
  1. iPod Touch 5th Generation LCD Shield Plate Replacement, Front Panel: шаг 1, изображение 1 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement, Front Panel: шаг 1, изображение 2 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement, Front Panel: шаг 1, изображение 3 из 3
    • Lay overlapping strips of clear packing tape over the iPod's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 2, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 2, изображение 2 из 2
    • Use a hair dryer or prepare an iOpener and apply it to the lower edge of the iPod for about a minute in order to soften up the adhesive underneath.
    • The bottom of the screen (near the home button) is held in place with strong adhesive.
    • As you start prying the screen off in the next stages, you may need to apply more heat to keep the glue warm and flexible.
  3. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 3, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 3, изображение 2 из 2
    • Center the suction cup on the lower section of the glass, with its edge centered over the home button.
    • Press in firmly and make sure the cup has a strong seal.
  4. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 4, изображение 1 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 4, изображение 2 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 4, изображение 3 из 3
    • Hold the iPod firmly against a table or bench.
    • Place your thumb and index finger over the lower corners of the display to stop the display from opening too far when the adhesive breaks.
    • Lift the suction cup up and back toward the top of the iPod. Be patient, and pull with firm, constant force until the adhesive breaks and the display comes up from the rear case.
    • It may be necessary to use a heat gun to soften the adhesive (especially in cooler climates). If you can pry the screen apart, and the adhesive is still sticking and pulling apart like cheese topping on a pizza, you can slide a thin razor blade in and gently cut the adhesive.
    • After the display begins to lift from the rear case, be careful not to lift more than about an inch—a fragile plastic frame still connects the display assembly to the rear case.
  5. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 5, изображение 1 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 5, изображение 2 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 5, изображение 3 из 3
    • In the following steps, you will be loosening and freeing the plastic frame that surrounds the screen. It is connected to the rear case with several clips.
    • Starting at the top right of the device, insert a plastic opening tool into the gap between the plastic frame and the aluminum rear case.
    • Slide the tool down this crack, loosening the frame from the case.
  6. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 6, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 6, изображение 2 из 2
    • Insert the plastic opening tool between the frame and the rear case behind the first clip.
    • Rock the tool sideways, to spread the gap behind the clip and separate it from the rear case.
    • This may not free the clip initially, but repeating the procedure for each clip will begin to loosen the piece.
  7. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 7, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 7, изображение 2 из 2
    • Repeat the procedure with the next two clips on this side.
    • You may have to go back and forth between the clips to free all of them. Take your time and be careful and patient, as the plastic frame is quite fragile.
  8. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 8, изображение 1 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 8, изображение 2 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 8, изображение 3 из 3
    • Moving on to the left side of the device, insert a plastic opening tool into the gap between the plastic frame and the aluminum rear case near the top.
  9. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 9, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 9, изображение 2 из 2
    • Insert the plastic opening tool between the frame and the rear case behind the first clip on the left side.
  10. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 10, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 10, изображение 2 из 2
    • Insert the plastic opening tool between the plastic frame and aluminum rear case behind the second clip.
    • Rock the tool sideways, loosening the clip from the case.
  11. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 11, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 11, изображение 2 из 2
    • Using the same procedure, loosen the last clip securing the plastic frame to the rear case.
  12. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 12, изображение 1 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 12, изображение 2 из 3 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 12, изображение 3 из 3
    • Insert the plastic opening tool between the display assembly and the rear case near the top of the iPod.
    • Slightly twist the opening tool to pry the front panel up from the rear case.
    • Separate the display assembly from the iPod.
    • Do not try to completely remove the front panel, as it is still connected by several cables.
  13. iPod Touch 5th Generation LCD Shield Plate Replacement, LCD Shield Plate: шаг 13, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement, LCD Shield Plate: шаг 13, изображение 2 из 2
    • Gently fold the display over away from the rest of the iPod, taking care not to disconnect or break any of the ribbon cables. Set the two halves flat on a table or bench.
    • If your iPod has a black home button assembly rather than the orange one shown here, you can skip this step. The button is not attached to the LCD plate and does not need to be removed to complete the repair.
    • Use a plastic opening tool to pry the home button switch up from the LCD plate.
    • It may be necessary to use a heat gun or hair dryer to soften the adhesive on the back of the home button. Always use a low heat setting.
    • Do not attempt to remove the home button switch, as it is connected to components below the LCD plate.
  14. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 14, изображение 1 из 1
    • Remove the following screws securing the LCD plate to the rear case:
    • Two 1.2 mm #000 Phillips screws
    • Nine 1.6 mm #000 Phillips screws
    • One 2.3 mm #000 Phillips screw
  15. iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 15, изображение 1 из 2 iPod Touch 5th Generation LCD Shield Plate Replacement: шаг 15, изображение 2 из 2
    • Lift up and remove the LCD plate from the iPod.
Заключение
7 человек успешно провели ремонт по этому руководству.
Andrew Optimus Goldheart
Участник с: 10/17/09
512 205 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 605 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 31
За всё время: 16,890
