Введение
prerequisite
Запчасти
Детали не указаны.
  1. iPod Touch 5th Generation Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 1, image 1 of 1
    • Use the tip of a spudger to peel back a small piece of tape covering a screw on the left side of the headphone jack.
  2. iPod Touch 5th Generation Lightning Connector Assembly Replacement: step 2, image 1 of 1
    • Remove the following screws securing the headphone jack, Lightning connector, and speaker.
    • Three 2.6 mm #000 Phillips screws
    • Two 2.0 mm #000 Phillips screws
  3. iPod Touch 5th Generation Lightning Connector Assembly Replacement: step 3, image 1 of 1
    • Use the flat end of a spudger to pry the speaker up from the rear case.
    • Do not try to remove the speaker, as it is soldered to the Lightning connector assembly.
  4. iPod Touch 5th Generation Lightning Connector Assembly Replacement: step 4, image 1 of 2 iPod Touch 5th Generation Lightning Connector Assembly Replacement: step 4, image 2 of 2
    • Grasping the large ribbon cable, gently pull the Lightning connector assembly out of the bottom of the case.
Заключение
Andrew Optimus Goldheart
Участник с: 17.10.2009
490 211 Репутация
Автор 410 руководств
iFixit Участник iFixit
Community
144 членов
Автор 16 273 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 218
