iPod shuffle 3rd Generation Front Case Replacement
Выберете то, что вам нужно
  1. iPod shuffle 3rd Generation Front Case Replacement, Rear Case: шаг 1, изображение 1 из 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod shuffle 3rd Generation Front Case Replacement: шаг 2, изображение 1 из 2 iPod shuffle 3rd Generation Front Case Replacement: шаг 2, изображение 2 из 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod shuffle 3rd Generation Front Case Replacement: шаг 3, изображение 1 из 1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod shuffle 3rd Generation Front Case Replacement: шаг 4, изображение 1 из 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod shuffle 3rd Generation Front Case Replacement, Logic Board: шаг 5, изображение 1 из 1
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod shuffle 3rd Generation Front Case Replacement: шаг 6, изображение 1 из 1
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod shuffle 3rd Generation Front Case Replacement: шаг 7, изображение 1 из 1
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
  8. iPod shuffle 3rd Generation Front Case Replacement, Headphone Jack & Shuffle Switch: шаг 8, изображение 1 из 1
    • Pry the headphone jack from the front case with an iPod opening tool.
    • Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
  9. iPod shuffle 3rd Generation Front Case Replacement: шаг 9, изображение 1 из 1
    • Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
  10. iPod shuffle 3rd Generation Front Case Replacement: шаг 10, изображение 1 из 1
    • Remove the headphone jack and shuffle switch from the front case.
Заключение
2 участников успешно повторили данное руководство.
Matthew Newsom
Участник с: 01/05/10
39 527 Репутация
Автор 67 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 22
За всё время: 6,511
