iRULU AX106 Battery Replacement
Выберете то, что вам нужно
  1. iRULU AX106 Battery Replacement, iRULU AX106 Disassembly: шаг 1, изображение 1 из 1
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Battery Replacement: шаг 2, изображение 1 из 2 iRULU AX106 Battery Replacement: шаг 2, изображение 2 из 2
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Battery Replacement: шаг 3, изображение 1 из 3 iRULU AX106 Battery Replacement: шаг 3, изображение 2 из 3 iRULU AX106 Battery Replacement: шаг 3, изображение 3 из 3
    • Using a pair of tweezers, gently unplug connectors A and B from the logic board.
    • Completely separate the screen and case.
  4. iRULU AX106 Battery Replacement, Battery: шаг 4, изображение 1 из 2 iRULU AX106 Battery Replacement, Battery: шаг 4, изображение 2 из 2
    • The battery is located right above the logic board, and can be identified as a large flat black rectangle.
    • Use the plastic opening to scrape away the glue that is holding down the battery.
  5. iRULU AX106 Battery Replacement: шаг 5, изображение 1 из 1
    • You should see that the battery is connected by 2 wires, one black and one red that lead to the logic board.
    • Make note of what color wire is soldered to the respective node before un-soldering the wires.
    • Heat up a soldering iron and melt the solder that is connecting the battery to the logic board.
    • Use a solder sucker to remove the solder as it melts, using caution to remove the wire.
    • Completely remove the battery from the device.
    • Insert the new battery and re-solder the corresponding wires to their respective locations.
Заключение
2 участников успешно повторили данное руководство.
James McLean
Участник с: 03/24/15
9 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 Участник UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G7
3 членов
Автор 8 руководств
3 Комментариев
Where do you get a new battery
Janet dowdy - Ответить
The batteries should be in a holder, not have to unsolder and solder. Most people do not have a soldering iron.
Lynn Buckingham - Ответить
Is that a iPad battery?
Yanny 57 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 4,017
