Выберете то, что вам нужно
Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
Using a pair of tweezers, gently unplug connectors A and B from the logic board.
Completely separate the screen and case.
Инструмент, используемый на этом этапе:Desoldering Pump$3.99
Insert the new speaker heads where the old speakers were previously.
Now use the soldering iron to solder the leads of the two speakers onto the logic board.
