iRULU AX106 Speaker Replacement
Выберете то, что вам нужно
  1. iRULU AX106 Speaker Replacement, iRULU AX106 Disassembly: шаг 1, изображение 1 из 1
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Speaker Replacement: шаг 2, изображение 1 из 2 iRULU AX106 Speaker Replacement: шаг 2, изображение 2 из 2
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Speaker Replacement: шаг 3, изображение 1 из 3 iRULU AX106 Speaker Replacement: шаг 3, изображение 2 из 3 iRULU AX106 Speaker Replacement: шаг 3, изображение 3 из 3
    • Using a pair of tweezers, gently unplug connectors A and B from the logic board.
    • Completely separate the screen and case.
  4. iRULU AX106 Speaker Replacement, Speaker: шаг 4, изображение 1 из 1
    • Locate the two speakers and using the soldering iron and solder sucker carefully remove the solder that binds the two speakers down.
    • Insert the new speaker heads where the old speakers were previously.
    • Now use the soldering iron to solder the leads of the two speakers onto the logic board.
    • Be careful, the soldering iron will be extremely hot.
Заключение
Andrew Mele
Участник с: 03/24/15
146 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 Участник UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G7
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 327
