Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removing the brush guard will be easy. It won't take more than 5 minutes to complete and no tools are required.
Lay the Roomba upside down on a flat surface with the blue strip away from you.
Use your index fingers to pull the yellow tabs towards you.
While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
Pull back the brush guard to unhook it from the latches.
Remove the brush guard by lifting it up and out of the Roomba.
