Введение
The battery is quite simple to replace in a Roomba, and only requires removing the side brush and bottom plate before it can be accessed.
Инструменты
Запчасти
Детали не указаны.
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Lift and remove the old battery by pulling the tabs on both sides.
Gently replace with a new battery.
6 участников успешно повторили данное руководство.
