Введение
This guide explains how to remove the brush case from your Roomba.
Инструменты
Запчасти
Детали не указаны.
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Push on the dirt bin release button, and pull gently.
Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
Еще один человек закончил это руководство.
