Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide explains how to remove the brushes from your iRobot Roomba 551, either for replacement or cleaning.
Выберете то, что вам нужно
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Pinch the yellow tabs on the sides of the brush cage and lift up to open.
2 Комментариев
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
