Введение
Is your Roomba banging its head against the wall? Follow this guide to replace the bumper sensor.
Выберете то, что вам нужно
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
Flip the bumper over and lift the sensor from its compartment.
You are now free to replace the bumper sensor.
4 участников успешно повторили данное руководство.
