Введение
This guide explains how to remove the faceplate from your Roomba.
Выберете то, что вам нужно
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Push on the dirt bin release button, and pull gently.
Might as well do this first, so you don’t dump dirt everywhere when flipping Roomba over.
With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
Pull up on the front of the faceplate until the friction locks pop out of place.
Continue around the outside of the Roomba, pulling up on the faceplate to free all of the outer friction locks.
Grab the faceplate by the outer edge and pull upwards, freeing the center friction locks in the process.
Еще один человек закончил это руководство.
Один комментарий
If all you need off is the faceplate, you can start at step 11 and skip the 1-10. The bottom and bumper assemblies seem completely unrelated to the faceplate. I removed the dirt bin and started lifiting at the back edge, then worked around the faceplate and it just popped off with no damage.
There are 4 long friction tabs around the circumference, and no tabs at the center. Once the outer friction tabs are free, the center circle of the faceplate comes off cleanly, leaving the display panel, control buttons and the chrome-ish ring. Under the 'IR' in the IRobot logo on the faceplate is the SCI port, more plastic and a number of screws to get to the motherboard.
If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
David Forrest - Ответить
