Введение
This guide explains how to remove the main brush motor from your Roomba.
Выберете то, что вам нужно
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Push on the dirt bin release button, and pull gently.
Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach.
Repeat for the opposite side of the brush case.
Use a Phillips #1 screwdriver to remove the three 5.0mm screws from the back of the brush case.
Pull off the back of the brush case.
Use a Phillips #1 screwdriver to remove the two 1.5mm screws securing the chip in place.
Remove the chip from its housing in the blue brush case.
Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place.
Use a Phillips #1 screwdriver to remove the two 4.5mm screws on the top and bottom of the metal plate.
Pull out the motor and metal covering.
Use a Phillips #1 screwdriver to remove the two 3.5mm screws on the corners of the circuit board.
Gently pull out the circuit board.
2 участников успешно повторили данное руководство.
