Введение
This guide explains how to remove the side brush motor from your Roomba.
Выберете то, что вам нужно
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
