iRobot Roomba 650 Caster Wheel Replacement
Выберете то, что вам нужно
  1. iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: шаг 1, изображение 1 из 2 iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: шаг 1, изображение 2 из 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: шаг 2, изображение 1 из 2 iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: шаг 2, изображение 2 из 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Caster Wheel Replacement, Caster Wheel: шаг 3, изображение 1 из 1
    • Begin by pulling on the caster wheel. It should pop out of its housing fairly easily.
  4. iRobot Roomba 650 Caster Wheel Replacement: шаг 4, изображение 1 из 2 iRobot Roomba 650 Caster Wheel Replacement: шаг 4, изображение 2 из 2
    • Once caster wheel is off the Roomba, push on the wheel so that it slides out of the groves it sits in.
Заключение
2 человек успешно провели ремонт по этому руководству.
Alex Schnorr
Участник с: 01/22/15
649 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 19-7, Maness Winter 2015 Участник Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 членов
Автор 6 руководств
3 Комментарии к руководству
Alternate instructions.
1. skip steps 1 and 2. you don't need to take the panel off to remove the caster wheel.
2. follow steps 3 and 4.
Matt Johnson - Ответить Поделиться
Worked for my 690 as well.
Luke Oliver - Ответить Поделиться
Hi, my caster wheel drops out easiy from the groves… a bit like the groves are worn out already and are no longer able to hold the wheel metal spoke in place. I would like to know if this can be fixed without resorting to buying a new wheel? (Reduce, Reuse, Recycle) Please help?
Rykel Lim - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 51
За всё время: 2,606
