iRobot Roomba 655 Pet Series Drive Wheels Replacement
Выберете то, что вам нужно
  1. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: шаг 1, изображение 1 из 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: шаг 1, изображение 2 из 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: шаг 2, изображение 1 из 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: шаг 2, изображение 2 из 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: шаг 3, изображение 1 из 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: шаг 3, изображение 2 из 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: шаг 3, изображение 3 из 3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: шаг 4, изображение 1 из 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: шаг 4, изображение 2 из 2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: шаг 5, изображение 1 из 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: шаг 5, изображение 2 из 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: шаг 5, изображение 3 из 3
    • Remove the three screws with your Phillips head #1, holding the drive wheels in place
    • These three screws will stay in place and won't come out of the plastic
  6. iRobot Roomba 655 Pet Series Drive Wheels Replacement: шаг 6, изображение 1 из 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: шаг 6, изображение 2 из 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: шаг 6, изображение 3 из 3
    • Unscrew the actual wheel from the blue plastic holder
    • Pull apart the blue holder to completely remove the wheel
  7. iRobot Roomba 655 Pet Series Drive Wheels Replacement: шаг 7, изображение 1 из 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement: шаг 7, изображение 2 из 2
    • To go further into the holder to access the programming chips you can unscrew these compartments
Заключение
Еще один человек закончил это руководство.
Rhett
Участник с: 01/22/15
1 329 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 21-20, Maness Winter 2015 Участник Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 2,252
