Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
You will be removing the front bumper (this runs into objects and walls) from the Roomba to gain access to the control center (display) and motherboard.
Запчасти
Детали не указаны.
  1. Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver. Pull the plastic bumper protector up and off of the bumper.
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  2. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  3. Flip the Roomba back over, so you are viewing the top. Pull up on the front bumper to remove it. Be careful not to pull too hard because there is wiring attached to the bumper.
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
Заключение
Rhett
Участник с: 22.01.2015
1 121 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 21-20, Maness Winter 2015 Участник Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 66
За всё время: 1,829
