Выберете то, что вам нужно
Use a #2 Phillips screwdriver to remove the 7.7 mm screw securing the side brush head.
Remove the yellow brush head.
Place the Roomba with its bottom facing toward you.
Use a Phillips #2 screwdriver to remove the four 11 mm screws.
Remove the battery cover.
On the underside of the Roomba, use a Phillips #1 screwdriver to remove the two 15.5 mm screws.
Grip the side brush module casing and lift it out vertically, perpendicular to the Roomba.
