Введение
This guide will instruct you how to replace the side wheels of the iRobot Roomba 960. The wheels should be replaced when worn or broken.
Выберете то, что вам нужно
Turn the Roomba upside down and orient it so that the wheels are facing upwards and the dustbin is furthest from you.
Using the two black flaps located at the sides of the battery, pull it towards you.
Carefully remove the battery.
With the Flathead 2.5mm screwdriver remove the 7.9mm screw from the side-brush.
Using a Phillips #1 screwdriver, unscrew the two 11.4mm screws that hold the bottom cover.
Lift to remove the plastic back panel.
2 участников успешно повторили данное руководство.
Один комментарий
In steps 2, 3 and 4 you show how to remove the battery, but from steps 5-9 you show the battery installed. Is it required to remove the battery?
If this is a required safety procedure to remove the battery, I would suggest to edit the pictures in steps 5-9 showing the battery removed in those steps. If it is not required or stated in the repair instructions I would suggest to edit step 2 stating it is "Your suggestion but not necessary to remove the battery" or remove steps 2-4 & renumber the following steps.
I did something like this on another site & caught a lot of flack over it. In that one, I took pictures as I did the repair with the battery in, but forgot to mention it would be safer to remove the battery (only suggested in the instructions) to prevent damage from a short. But being a mechanic & knowing I could do the repair safely w/o removing the battery I didn't show the battery removed & someone damaged their equipment. Just a suggestion to save you from a possible big headache.
