Введение
This guide will help you replace the iRobot Roomba e5 battery. If your Roomba won't turn on, try to see if it will charge first. If the Roomba doesn't charge or turn on, the battery may need to be replaced.
Выберете то, что вам нужно
Flip the iRobot upside down
locate the edge sweeping brush which has a screw in the center.
Loosen the screw using a Phillips #1 screwdriver.
Loosen the five captive screws on the bottom of the Roomba using a Phillips #1 screwdriver.
Еще один человек закончил это руководство.
