iVIEW-754TPC Digitizer Replacement
Выберете то, что вам нужно
  1. iVIEW-754TPC Digitizer Replacement, Rear Panel: шаг 1, изображение 1 из 3 iVIEW-754TPC Digitizer Replacement, Rear Panel: шаг 1, изображение 2 из 3 iVIEW-754TPC Digitizer Replacement, Rear Panel: шаг 1, изображение 3 из 3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Digitizer Replacement, Remove Battery: шаг 2, изображение 1 из 3 iVIEW-754TPC Digitizer Replacement, Remove Battery: шаг 2, изображение 2 из 3 iVIEW-754TPC Digitizer Replacement, Remove Battery: шаг 2, изображение 3 из 3
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Digitizer Replacement, Camera Assembly: шаг 3, изображение 1 из 3 iVIEW-754TPC Digitizer Replacement, Camera Assembly: шаг 3, изображение 2 из 3 iVIEW-754TPC Digitizer Replacement, Camera Assembly: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • The camera module is located directly under the top right corner of the back cover.
    • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
    • As you peel the tape backward, the front facing camera may come out, this is not an issue.
    • If the front facing camera does not come out, gently lift it out with a pair of tweezers
  4. iVIEW-754TPC Digitizer Replacement, Remove Camera: шаг 4, изображение 1 из 2 iVIEW-754TPC Digitizer Replacement, Remove Camera: шаг 4, изображение 2 из 2
    • Use a spudger to lift flap on top of the camera ZIF adapter.
    • At this point the camera module can be easily removed with a pair of tweezers.
    • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
  5. iVIEW-754TPC Digitizer Replacement, Logic Board: шаг 5, изображение 1 из 1
    • Remove the four 2.2mm Phillips screws holding the logic board in place. Place the screws on the iFixit magnetic project mat.
  6. iVIEW-754TPC Digitizer Replacement, WIFI Antenna: шаг 6, изображение 1 из 2 iVIEW-754TPC Digitizer Replacement, WIFI Antenna: шаг 6, изображение 2 из 2
    • Gently peel the WIFI Antenna up using a pair of tweezers.
  7. iVIEW-754TPC Digitizer Replacement, Disconnect LCD: шаг 7, изображение 1 из 3 iVIEW-754TPC Digitizer Replacement, Disconnect LCD: шаг 7, изображение 2 из 3 iVIEW-754TPC Digitizer Replacement, Disconnect LCD: шаг 7, изображение 3 из 3
    • Use a spudger to lift the flap on top of the LCD ZIF socket.
    • Gently remove the ribbon cable from the socket using a tweezers.
  8. iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: шаг 8, изображение 1 из 3 iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: шаг 8, изображение 2 из 3 iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: шаг 8, изображение 3 из 3
    • Use a spudger to lift the flap on top of the digitizer ZIF socket.
    • Gently pull the tape attached to the ribbon cable to remove the cable from its socket.
  9. iVIEW-754TPC Digitizer Replacement, Remove Logic Board: шаг 9, изображение 1 из 3 iVIEW-754TPC Digitizer Replacement, Remove Logic Board: шаг 9, изображение 2 из 3 iVIEW-754TPC Digitizer Replacement, Remove Logic Board: шаг 9, изображение 3 из 3
    • Gently slide the spudger below the logic board at the left side nearest the battery. Lift upward and away from the power button and bottom connectors.
    • The battery is still attached to the logic board. Be careful to not tear the two apart during removal.
  10. iVIEW-754TPC Digitizer Replacement, LCD: шаг 10, изображение 1 из 3 iVIEW-754TPC Digitizer Replacement, LCD: шаг 10, изображение 2 из 3 iVIEW-754TPC Digitizer Replacement, LCD: шаг 10, изображение 3 из 3
    • Insert a plastic opening tool between the LCD and digitizer on the side of the LCD with the ribbon cable. Use a second plastic opening tool to lift the LCD from the digitizer. Repeat this process on both sides of the LCD ribbon cable.
    • Fully remove the LCD from the digitizer.
Заключение
Еще один человек закончил это руководство.
Robert Clark
Участник с: 01/21/15
1 065 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 5-4, Brown Winter 2015 Участник USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 членов
Автор 16 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,174
