Примечание: Вы редактируете необходимое руководство. Любые внесённые вами изменения влияют на все 47 руководства, которые включают этот шаг.
Английский
Французский
Перевод шага 3
Шаг 3
During reassembly, gently push down the center of the lower case to reattach the two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips.
  • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  • The lower case is connected to the upper case at the center, with two plastic clips.
Le boîtier inférieur est connecté au boîtier supérieur par deux attaches en plastique au milieu.
Lors du remontage, appuyez doucement sur le milieu du boîtier inférieur pour que les deux attaches s'enclenchent à nouveau.
-[* icon_note] The lower case is connected to the upper case at the center, with two plastic clips.
[* icon_reminder] During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
+ [* red] The lower case is connected to the upper case at the center, with two plastic clips.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
