Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Английский
Французский
Шаг 7
Flip up the retaining flaps on each end of the I/O board ribbon cable ZIF connector. Carefully pull the the I/O board ribbon cable from its sockets. Remove the two 4.6 mm screws holding the hard drive in place.
  • Flip up the retaining flaps on each end of the I/O board ribbon cable ZIF connector.
  • Carefully pull the the I/O board ribbon cable from its sockets.
  • Remove the two 4.6 mm screws holding the hard drive in place.
Relevez les rabats de retenue à chaque extrémité du connecteur ZIF du câble à ruban de la carte d'E / S.
Tirez délicatement le câble ruban de la carte d'E / S de ses prises.
Retirez les deux vis de 4,6 mm maintenant le disque dur en place.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
