Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Английский
Французский
Шаг 2
Remove the panel covering the RAM. Pull the two RAM retaining arms away from the center of the RAM chip. Gently pull the RAM chip out of its socket.
  • Remove the panel covering the RAM.
  • Pull the two RAM retaining arms away from the center of the RAM chip.
  • Gently pull the RAM chip out of its socket.
  • This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
Retirez le panneau recouvrant la RAM.
Tirez les deux bras de retenue de la RAM loin du centre de la puce de RAM.
Tirez doucement la puce de RAM de son support.
Cette photo montre la batterie encore en place, mais vous devez la retirer avant de retirer ou de remplacer la RAM.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
