why! N131WU/BU/ZU RAM Replacement
Выберете то, что вам нужно
  1. why! N131WU/BU/ZU RAM Replacement, Remove the Screws: шаг 1, изображение 1 из 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: шаг 2, изображение 1 из 3 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: шаг 2, изображение 2 из 3 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: шаг 2, изображение 3 из 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: шаг 3, изображение 1 из 3 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: шаг 3, изображение 2 из 3 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: шаг 3, изображение 3 из 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: шаг 4, изображение 1 из 2 why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: шаг 4, изображение 2 из 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU/BU/ZU RAM Replacement, RAM (Memory): шаг 5, изображение 1 из 3 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): шаг 5, изображение 2 из 3 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): шаг 5, изображение 3 из 3
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
Заключение
To reassemble your device, follow the instructions in reverse order.
Особая благодарность этим переводчикам:
fr en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Felice Suglia
Участник с: 06/15/13
33 538 Репутация
Автор 283 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 533
