The second-gen Flip MinoHD hit the market in October, and is currently the best-selling digital MiniDV camcorder on Amazon.
Consumers definitely love it, but we were curious to see what kind of electronics were packed into this simplistic yet customizable half-aluminum, half-plastic device.
Is the Flip MinoHD’s $230 price tag really justified, or is this just a tidy, sleek-looking cash cow for Pure Digital?
There was only one way to find out: teardown time.
Teardown Highlights:
- Capacitive sensors under each of the control symbols (play, back, etc.) provide the logic board with control data, while small LEDs mounted to the logic board under each “button” project light through the front panel to provide their illumination.
- The MinoHD sips two hours worth of power from the internal 3.7V, 1150 mAh Li-ion battery. The battery weighs in at 30 grams. Coincidentally, this is the same capacity as the iPhone 3G.
- Cisco is using 8 GB of Samsung NAND flash.
- The microphone assembly on the left also houses a small speaker for audio output during video playback. It connects to the board via two spring-loaded pressure contacts.
- Once the USB axle clears the outer case, the flip-up USB connector may be ejected at high speed. Wear safety glasses if taking apart the MinoHD.
- The high definition CMOS sensor has .0000022 meter wide pixels to capture clear 720p video.
- The MinoHD uses a Zoran COACH (camera on a chip) 12 processor featuring real-time lens distortion compensation and noise reduction.
Some cool pictures to whet your appetite:
0 Комментариев
