Update July 11, 2022: Our microsoldering friends have taught us that desiccant packets will not prevent corrosion from continuing to spread within a sealed device. Currently, our best recommendation for a waterlogged device is to take it apart, air dry it, and clean it with alcohol; see this post for more. We have not sold the Thirsty Bag for several years.
If you have ever dropped a phone in a pool or spilled water on your Game Boy, then you know the helplessness of water damaged electronics.
When water comes into contact with an electronic device, it tries to seep into any nook and cranny it can possibly get into. If one of those crannies happens to be near the motherboard, the water may cause a short, rendering parts of the device, or the entire device, useless.
The first step for fixing a wet device is always to immediately turn it off and remove the battery, if possible. As long as no power is flowing through the motherboard, there is no way that the water can cause a short. But how do you get all the water out? That’s where this bag of thirst comes in.
Introducing the Thirsty Bag – the bag that is guaranteed to absorb 100% of the water out of your device and help get it running again. Using the Thirsty Bag directly after an accident can dramatically reduce the chances of a short.
We use molecular sieves, the best in desiccant technology, inside the bags to absorb the maximum amount of water from the environment. Molecular sieves work by allowing small molecules (such as water) through their pores while concurrently blocking out larger molecules (the rest of your device). What does that mean for you? Ridding yourself of every drop of liquid in your device.
The Thirsty Bag is big enough to work for PSPs, watches, cameras, calculators, PDAs, and more. It can even dry your larger electronics, like iPads and DSLR cameras, if you use a larger sealable bag. And unlike other home remedies — such as uncooked rice or direct sunlight — these pouches are guaranteed to absorb all of the water out of the device without any risk of damage.
Fair warning: using the Thirsty Bag will ensure that there will be no liquid left inside to cause a short, but it will not guarantee that your device will work afterwards. Think of it as an electronic bandage. You’ll use a bandage if you get shot (and it’ll even extract the bullet for you in this example), but it won’t guarantee that you’ll live. So just as it’s handy to have some bandages around in case you get into a gunfight, it’s handy to have the Thirsty Bag around just in case you drop your iPhone into the toilet while reading this blog post.
Один комментарий
iFixit has admitted that products such as the Thirsty Bag do not work. They are actually worse for your wet phone than just leaving it out in the air to dry. See this article: https://www.ifixit.com/News/rice-is-for-...
facebook - Ответить
