Выберете то, что вам нужно
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Floppy Disk, воспользуйтесь нашим сервисным руководством.
  1. Floppy Disk Teardown, Floppy Disk Teardown: шаг 1, изображение 1 из 2 Floppy Disk Teardown, Floppy Disk Teardown: шаг 1, изображение 2 из 2
    • The floppy disk has gone the way of the dinosaur.
    • Except for Google's lovable jumping dinosaur.
    • These disks might hold one or two photos at best; they probably won't hold much more though at only 2MB.
    • It's worth noting that today's photos taken can be upwards of 10MB on their own!
    • We liked skimmilk05's teardown so much (and his amazing attempt at his own teardown graphic) we supplied one of our own for this truly unique community contributed teardown. - iFixit Staff <3
  2. Floppy Disk Teardown, Removing the Cover: шаг 2, изображение 1 из 2 Floppy Disk Teardown, Removing the Cover: шаг 2, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Jimmy
    $7.95
    Купить
    • Thin metal pieces are good places to start.
    • This one's so thin that you can bend it with a finger.
    • This one wasn't too hard, but if you're having trouble getting it up, a Jimmy comes in handy.
  3. Floppy Disk Teardown, Removing the Casing: шаг 3, изображение 1 из 3 Floppy Disk Teardown, Removing the Casing: шаг 3, изображение 2 из 3 Floppy Disk Teardown, Removing the Casing: шаг 3, изображение 3 из 3
    • With some careful prying, the entire lid pops right off.
    • You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was.
    • There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
    • And we get a glimpse of what's inside! Spoiler alert: not much is there.
  4. Floppy Disk Teardown, The Spring: шаг 4, изображение 1 из 1
    • In cracking open the casing, we lost a tiny little spring.
    • Boing.
    • Boing.
    • Playtime's over. Best guess as to what it is? Keeping that metal piece over the tape inside.
  5. Floppy Disk Teardown, The Cleaning Pad: шаг 5, изображение 1 из 1
    • On the inside, we see a small pad, probably to clean the turning disk that's inside.
    • This one was pretty nasty. Eww.
    • This pad is glued into the casing with some tough adhesive; the manufacturer really didn't want this pad coming out on its own.
    • Aha!
    • The meat n' bones of the floppy disk, the disk itself!
    • Ever wondered why the floppy disk was called the "floppy" disk, even though it was in that hard plastic case? This is why.
  6. Floppy Disk Teardown, The Disk: шаг 7, изображение 1 из 2 Floppy Disk Teardown, The Disk: шаг 7, изображение 2 из 2
    • More floppy goodness.
  7. Floppy Disk Teardown, Wrap-up: шаг 8, изображение 1 из 1
    • It's a pretty simple device in all. Not much else to say here.
  8. Floppy Disk Teardown, Final Thoughts: шаг 9, изображение 1 из 2 Floppy Disk Teardown, Final Thoughts: шаг 9, изображение 2 из 2
    • Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair)
    • This antique technology has virtually no replacement parts.
    • Replacement of the tape or cleaning pads are impossible without breaking the case.
    • The cleaning pads are held on with tight adhesive, making replacement difficult.
    • Attempts to use heat to loosen adhesive may result in the case melting.
    • High susceptibility to magnets make this device very sensitive.
Seji the veggie
Участник с: 02/09/15
1 986 Репутация
1 руководство автора
10 Комментариев
Super cool! Haven't seen a floppy disk in forever.
Taylor Whitney - Ответить
They are a tad old...haha
Seji the veggie -
This is amazeballs. Solid work!
Kay-Kay Clapp - Ответить
"floppy goodness" -- so good
Julia - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 50
За всё время: 10,505
