Отремонтируйте ваше устройство
Обучение ремонту
Магазин
MacBook Air (Original) Fan and Heat Sink
  • MacBook Air (Original) Fan and Heat Sink
39,99 $
39,99 $
Мы отправим сообщение, когда товар будет в наличии.
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
Shop Kits
Enough RAM
For All The Tabs
Shop Kits
Спецификации
Описание
Описание
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your model A1237 MacBook Air to overheat and eventually damaging your processors. Replace a defective fan and heat sink to fix overheating problems or to keep your laptop running quietly.
Часть сборки включает
  • Fan
  • Attached Heat Sink
Совместимость
Совместимость
  • 1.6 or 1.8 GHz Original MacBook Airs
Характеристики
Характеристики
Part #:
922-8316
Видеоинструкция по установке
Совместимость
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
Истории ремонта
Фото профиля
Моя проблема
The fan was making a whistle noise... and the CPU was too hot for MBA to work normally.
Моё решение
Changed the fan. Cleaned the inside of the laptop from dust…
Мой совет
Clean the inside at least twice a year…
Фото профиля
Моя проблема
Existing fan was loud
Моё решение
The repair went according to instructions. I like how all the different screws are identified. Made it really easy for reinstallation.
Мой совет
Ifixit shows instructions on how to remove the fan from the heatsink but does not offer the option of buy the fan only. I had to buy the heatsink . . .
Фото профиля
Моя проблема
The machine began to run a little hot with excessive fan activity. Eventually no fan, just a faint clicking sound and rising temperatures, which I diagnosed from various blogs as fan failure.
I hadn't checked the heatsink vs processor temperatures so couldn't confirm the state of the heat sink / . . .
Фото профиля
Моя проблема
So, my original MacBook Air's fan started making a *horrible* very, un-Apple-like screeching sound. I added some lubrication and that helped a little, but in the end it appeared the fan unit itself had just worn out after working at thousands of RPMs for many hours thru the years.
Моё решение
The repair took abo . . .
Показать еще
